Speedcam values
Moderator: GiveMeABreak
- bobins
- Donor 2023
- My Cars: Kia Sportage
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2893
Re: Speedcam values
The speedcam speed warnings innacurracy (using SCDB) on RNEG is normal. I always put it down to the fact that they had to convert UK mph values into km/h with a small safety margin and then have to convert km/h back into mph with another small saftey margin.
Sadly no longer a C5 owner
- My Cars: Citroen C5 Tourer
Re: Speedcam values
So, no way to sort it out?
Re: Speedcam values
Ok, thanks for your help and support!
- My Cars: 2010 C5 V6 HDi Tourer
2006 307SW HDi 136
1992 205 GRDT - x 3
Re: Speedcam values
I can confirm this issue as of recent speedcams from SCDB, still happening. What I've done is turn off the visual alert, and just use audio as hopefully you always know what the speed limit is lol.
Mira308SW of mirascripts fame made a program that could partially decompile the LWD files used to store the speed limits. I can't find the 2017-2 maps radar file, but if you could upload it somewhere then I could have a look at the two sets and see if I can see what the difference is to help SCDB fix it.
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
Re: Speedcam values
Ah, was that supposed to show the correct speed limit? I always thought it just thew up some random figure since it never seemed to match.
2006 307SW HDi 136
1992 205 GRDT - x 3
Re: Speedcam values
Thanks to ADY-ULTRAS for sending me some working and broken files, I've found out the following. I've used a speed camera I know well (set to 30mph) so I know the speed/location etc precisely.
It appears to be that if you set the "Limit mode" flag to 10, then you can store the speed in mph (30), whereas SCDB stores all values as Limit mode 13 (which I assume is kmh). In fact the working file uses 15, 7, 13, 9, 10 and other types of limit mode whereas every camera in scdb is set to 13. This I assume is the problem, although I'll have to conduct a bit more analysis to work out what the different types all mean (maybe mph, kmh, average speed etc?).
The file format LWD only lets you store speed limits in units of tens (30, 40, 50 etc) so I think what is happening is their tool is converting the UK speed limits to their nearest kmh equivalent (30 -> 45) and then when it's built into the LWD file it stores the nearest round number which is 40kph, which is 37mph, which the unit then shows. This doesn't happen with 50mph sections because 50 -> 80kph almost exactly.
I have no idea what tool SCDB use to build their database and what configuration options it might have, but if someone has an active SCDB subscription (mine came with car from prev. owner) its probably worth feeding this back to see if they can fix it (or get me an email address and I can explain it to them directly). I don't know if the tool I'm using can successfully re-build the hazardareas.lwd to a working file but I'll give it a try with this camera when I get some time in case they can't fix it themselves.
Code: Select all
Latitude Longitude Direction Limit flag Speed Limit mode (Section)
Working:
50.969862 -1.337513889 96 1 30 10 28
Broken:
50.969862 -1.337513889 96 1 40 13 20
Re: Speedcam values
Hi! I have a subscription on SCDB but I think it's better if you send an email to support@scdb.info and let them know about your discovery. Maybe it will be sorted! Good luck!
Re: Speedcam values
Hi guys! Any update in the values of the speedcams?
2006 307SW HDi 136
1992 205 GRDT - x 3
Re: Speedcam values
Sorry I've been super busy with work lately. On further investigation, the limit mode flag is actually used to set the warning distance (one at 600yd out, next at 200yd out). The determination of km/mph I think is set elsewhere inside the header of the LWD file and is done on a section-by-section basis. The file format is a bit strange and basically groups speedcams into geographic boxes. So I think somewhere in the header for each "box" is a flag for KM/mph. Mira and some others did a reasonable job documenting the LWD format, but the km/mph flag is not one of those found (since they were all european based I guess they had no reason to worry about mph!).
I tried manually analysing the undocumented sections of the header to try and spot a pattern, without success so far. I think this one may need to be filed under "impossible" unless someone can get hold of the tool that is used by PSA to generate the official maps.
Re: Speedcam values
Hi! Did you tried to get in contact with scdb ? They might be able to do something and if you help them they will give you free subscription.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Speedcam values
I've also looked into the LWD format with those tools and gave up as the files have checksums so any alteration and they won't compile. Some uf us were trying ti amend the radar zones and add personalised speed traps - but the failed to work so we resigned ourselves that without the appropriate software we can't amend them.
