Speedcam values
ADY-ULTRAS
Speedcam values
Hi! My navigation system it's showing me the next values for the SCDB speedcams:
- for 20 mph - 19 mph
- for 30 mph - 25 mph
- for 40 mph - 37 mph
- for 70 mph - 56 mph
I have the latest firmware (R50b_R50.03). I spoke with the SCDB admin and they don't know why and how to fix the issue. Did anyone have / had the same problem? Any ideas on how to fix it?!?
ADY-ULTRAS
Re: Speedcam values
I changed the units from mph to km/h and I reinstalled the firmware but the speedcam values are the same. Any other ideas?!?
OnlinePaul-R
- x 1940
Re: Speedcam values
It must be something to do with mph - Km/h as those figures equate as follows:
19 mph = 30 Km/h
25 mph = 40 Km/h
37 mph = 60 Km/h
56 mph = 90 Km/h
But exactly how that helps I don't know.
19 mph = 30 Km/h
25 mph = 40 Km/h
37 mph = 60 Km/h
56 mph = 90 Km/h
ADY-ULTRAS
Re: Speedcam values
Definetly it's something regarding the MPH to KM/H conversion but I don't know how to fix it...
OnlinePaul-R
- x 1940
Re: Speedcam values
I don't suppose your car is still under warranty is it?
OnlinePaul-R
- x 1940
Re: Speedcam values
I looked up SCDB to find out what it is as I'd never heard of it. I assumed that it was the standard built-in satnav you were talking about but now I'm not so sure. Having said that I don't think that matters and that you're going to have to throw the problem back to SCDB. I presume that the values were showing correctly right up until this latest update?
ADY-ULTRAS
Re: Speedcam values
The only correct values were showed by the 2017-2 maps, but the problem was that a lot of the speedcams were missing (for example on M1 there were no speedcams).
I sent to SCDB the 2017-2 maps to check and they told me that I am right but they don't know what or how to fix it.... and they told me that I'm the only one with this problem reported, that's why I'm asking here if it is any one else with this issue.
OnlinePaul-R
- x 1940
Re: Speedcam values
I'm afraid I'm out of ideas. Your car is earlier than mine but can you confirm what satnav/radio is fitted to your car?
ADY-ULTRAS
Re: Speedcam values
Any one have any idea on how to sort it out?!?
- x 1464
Re: Speedcam values
Can you clarify which one of the following were changed to create the problem: The RNEG firmware. the RNEG maps version, the SCDB database version?
ADY-ULTRAS
Re: Speedcam values
The only good speedcams file are the one from the 2017-2 maps. Every other version that I found on internet or the scdb speedcams file shows a lower value than the normal one, as I described in the first post...
- x 1464
Re: Speedcam values
In that case, the problem would seem to be in the SCDB database. Perhaps a comparison of the data formatting in the SCDB files will reveal a difference (just look at the the entry for a speed camera that is present in both versions).
Is the working speedcam database file the one supplied by Citroen?
ADY-ULTRAS
Re: Speedcam values
I think so, but the problem is that the number of speedcams is very limited, a lot of it are missing, on the 2017-2 maps. What's weird is that no one seems to have this issue...
