Side airbag light won't go away
Vuk1987
x 4
Re: Side airbag light won't go away
Unread post by Vuk1987 »
Xantia_V6 thank you, I didn't think of that. GiveMeABreak if I miss it, well, makes no difference, whenever i reconnect the battery ... kaboom :)
Whatever the solution is, even if I have to go to the repair shop to do it for me, I will let You know what the solution was.
I heard many guys having an issue with that particular connector malfunctioning, ending up simply bypassing it by connecting the wires directly. If I've only looked before I took out the seat ...
Vuk1987
x 4
Today I first called Citroen repair shop and they've sent me to car electric repair shop. So I've asked them if they could fix the problem for me, once they've heard that the wires are all different color (seat side/floor side) they've said they can't, so I called the car electronics specialist and they've said that they have to use diagnostic tool in order to figure out what to do.
Tomorrow I'm going there, I just hope that they won't flay me. If they try to, I'll just connect the wires from the floor side using resistor and live without side airbag
Vuk1987
x 4
This morning I went to electronic repair shop and they’ve fixed the problem for me for around 10£. They did the same thing the previos guy did, connected the wires directly, only they’ve soldered them unlike the previous guy. I would prefer if they have puted a connector instead, but the problem is fixed and that’s all that matters. Here is wires connection order:
So yellow-green pairs with yellow green, orange pairs with blue and yellow pairs with brown.
I’ve had to peal a lot of tape in order to see this :)
So if anyone ever needs this, it’s here. BUT this is only for my type of car ONLY LEFT SIDED STEERING WHEEL, DRIVER SEAT, I don’t know if this is the right pairing for other types.
xantiagreen
Unread post by xantiagreen »
No time like the present, just been taking all the leads from under both seats apart shot of electrical contact cleaner and compressed air in a can and an hour later cobnect battery and 😁😁😁 the main airbag light has dissapeared, MOT is tomorrow morning so a possible failure avoided, now to getting the kids to stay in bed and sorting out the heating timer 🙄
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
x 1056
Unread post by wheeler »
Just wait till someone adjusts the seat & it will come back on, the only long term solution is to cut out the connections & solder the wires together.
xantiagreen
wheeler wrote: 31 Oct 2018, 08:22 Just wait till someone adjusts the seat & it will come back on, the only long term solution is to cut out the connections & solder the wires together.
I hope not, failed MOT on front rear P bushes both sides, so airbag light seems to be under control, had ti lie down in rear foot wells and get at passenger seat wiring, the drivers was from front i was half in half out with a head torch on for that side but all cables have already been soldered so just a quick clean up with air and few clicks of the cleaner.
Chap from liverpools coming over on weekend to look it over and hopefully drive back home in.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
