RNEG/ENEG2 Swap Problem
goggi10
Hi guys,
I have finally menage to swipe in my Citroen C5 X7 2012 RNEG with RNEG2 eMyway. But after swap when i turn on radio i can hear music but i have constant beeping and its very loud. One info i have just swap radio and display do i need to do some bsi changes and which one.
Can someone help me out.
OnlineHell Razor5543
- x 3292
Re: RNEG/ENEG2 Swap Problem
You need to 'introduce' the radio to the car. When the original radio was fitted at the factory the systems were informed as to serial numbers, and so they were 'part of the same team'. Now you have a different radio (and to put off thieves) you are getting the beeping every couple of seconds.
I had to replace the radio on my C5 Mk1. When I did it also was beeping. I managed (as I have a Lexia clone) to sort this out (probably through the radio diagnostic pages in the Lexia software), and the noise died mid-beep, and has never happened since. However, I cannot remember exactly what I did, as it was well over two years ago.
EDC5
- x 130
That is correct. The new head unit must have the VIN of your car programmed into it. You will need access to Diagbox/Lexia to do this.
Bjornar
- New User
Hi
Please forgive for asking before introducing myself to the forum, but did you manage to get rid of the beeping?
I've done a swap from RNEG1 to RNEG2 / rt6 on my 5008 too, but my local dealer claims they can't get contact with the unit from their system to code the VIN (which they charged me about £40 for).
Thanks!
Bjørnar
Thanks!
Bjørnar
- x 6954
There will likely be some other options that need to be coded or checked too, as if it is a second hand unit, it will likely have options programmed in from the previous car.
In either case of the VIN and the programming, it will have to be done via Lexia / PP2000.
You will have a problem if the ECU cannot be accessed to reprogram it.
goggi10
I have sucssefully register new unit to bsi via lexa i jave enabled all parking sensors only 2 thing are anoying to me and i can finde the option first scroll on the rigt sidw of wheel doeant work i cant scroll between station and second thing when i dimm light in car all orange light is dimmed in all car but 9n rt6 unite they are not doea sombody know whay and wherw to change this
- x 6954
Sorry Goggi - I really didn't understand much of what you said there - can you try and be precise, then use Google Translate as English clearly isn't your first language.
I think you say you have coded the VIN ok, but are having some other issues with the scroll wheels? What functions are you trying to operate?
goggi10
Sorry i have typed while i was in store hahahahah. I coded via lexia almost evrything but two funcrion is missing and i can find it. 1st one on the right side of wheel next to back butun you have a scroll and with that scroll i could scroll trough radio station when i click list buttun on the wheel but now after rneg rneg2 swipe that scroll doesnt work and when i click list on the wheel it doesnt show list of radio station.
2nd thing when you are dimming ambient ligjt all ambient light in car is dimming but only at rneg unit button light is bright and it doesnt dimming.
Do you maybe know the sution for this.
- x 6954
Have you changed any other settings in Diagbox that you perhaps should not have? I only say this as some options that are there are not intended for the X7’s configuration. For example the BSI has options for other cars that display information differently - and if these are changed, they can cause problems with the X7 controls and display.
The best thing to do is to take screen shots of each area if the settings in Diagbox, and I will have a look at these to compare with what they should be.
Areas to focus on are the RNEG2 ECU settings of course, but also the instrument panel settings too.
I will have a look through he configuration settings for the RT6 that I have, but can you please post up your VIN so I can determine the correct settings for the options on your car
goggi10
Hi
My vin is BL562351. With lexia i have registred my vin to the head unit, i have enabled vidwo mod (which doesnt work i will shut it off) and i have enabled front + rear parking sensors which i have but the didnt worked when i put RNEG2 unit in. Do i have to change something else. I dont like to use mira scripts.
Thamks
Thamks
- x 6954
Yes don’t do anything with Mirascripts yet as you might make it harder to troubleshoot. Before any ‘mods’ you need to get the basics working first. Can you post the FULL 17 digit VIN please.
goggi10
VF7**************[VIN obfuscated, can be read by forum staff] i found out that my RNEG2 is 2015 unit
- x 6954
Ok, here are the configuration tables for the RT6: Note I have marked the correct values for your car in green.
Note: For anyone else reading this - the settings below are specifically for a C5 X7 and for the specification of the OP's vehicle only!
Configuration of the Audio Functions
Configuration of the Other Functions / Personalisation Options
- USB Socket Setting in Yellow - you should of fitted this as part of the upgrade - as this setting is required although you did not have the USB originally.
- Items I have highlighted in Red: You must set these to the values I have marked. It does not mean you don't have A/C or Cruise Control - it is only concerning the Head Unit ECU.
- Items marked with a (2) in the end column must NOT be changed with any other value!
| Parameter to be Configured | Values to be Configured | Comments |
| CD Player | Absent Present | Absence CD Changer Presence Of CD Changer |
| HIFI Amplifier | Multiplexed Amplifier Electronic Amplifier | Presence Of A Bass Box Absence Of A Bass Box |
| USB Socket | Present | (2) |
| Auxiliary Audio Input | Present | (2) |
| Auxiliary Video Input | Absent Present | No Reversing Camera Presence Of A Reversing Camera |
| Video Input From The Reversing Camera | Absent Present | (1) |
| Fold-Away Multifunction Screen | Absent | (2) |
| Type Of Steering Wheel Controls | Condition 2 | (2) |
| Parking Assistance | Absent Present Rear Present Front & Rear | Without Parking Assistance Presence of Proximity Sensors in the Bumper (Rear) Presence Of Proximity Sensors in the Bumpers (Front & Rear) |
| Air Conditioning | Absent | (2) |
| Presence Of The Fold-Away Multifunction Screen | Absent | (2) |
| Multifunction Control Panel | Absent | (2) |
| Cruise Control | Absent | (2) |
| Noise Level Linked To Vehicle Speed | Active | (2) |
| Geographical Area Of Use | Europe JAPAN South America Asia And China Arab Countries | (1) According To Country |
| AM Waveband | Activated | (2) |
| Fader Function | Activated | (2) |
| Number of Radio Aerials | 2 | (2) |
| Type Of Antenna FM1/AM | Active Aerial | (2) |
| Type Of Antenna FM2 | Active Aerial | (2) |
| Digital Radio | Digital Radio Deactivated | (2) |
| Bluetooth Streaming Function | Activated | (2) |
| Parameter to be Configured | Values to be configured | Comments |
| Display of the External Temperature | Displaying Activated | (2) |
| Temperature Unit | Degrees Celsius | (2) |
| Time Display | Displaying Activated | (2) |
| Display of Languages & Units | Displaying Activated | (2) |
| Choice of Imperial Units for Trip Computer & Navigation | Metric | (2) |
| Speed Threshold for Locking of the Main Menu | Deactivated | (2) |
| Displaying of Alerts & "Hazardous Areas" on the Multifunction Screen | Displaying Activated | (2) |
| Display of the Speed Limit | Displaying Activated | (2) |
| Display of Audio Information on the Instrument Panel & on the Head Up Display | Display off | (2) |
| Displaying of the Navigation Instruction | Status Displayed on the Instrument Panel Matrix Display | (2) |
| Type of Intersection Zoom In the Instrument Panel Matrix | 16 Segments, With Street Names | (2) |
| Displaying of the Status Log | Displaying Activated | (2) |
| Displaying of the Warnings Log | Displaying Activated | (2) |
| Display of the Personalisation Menu | Displaying Activated | (2) |
| Trip Computer Function | Function Deactivated | (2) |
| Specific Welcome Page | Standard Page Standard Stop & Start Page | Without Stop & Start With Stop & Start |
| Selection of the Marque Logo for the Welcome Page | Citroën | (2) |
| Suspension IHM | Deactivated | (2) |
| Preferred SID (Automatic TMC Station) | France | (2) |
| Display of Vehicle Warning Messages | Displaying Activated | (2) |
| Separate Control Keypad | Absent | (2) |
goggi10
Thanks m8 i own you a dring as soon as i get nack im Serbia i will send you vie pay pal or western union to have a drink.
Many thanks. Pm me how i can send you a treat
- x 6954
No problems, but you may still have an issue - but at least getting the settings correct is the first step. Then you can try a BSI reset afterwards, which may reinitialise the BSI after all these configuration changes. No guarantees though
Donate Here
- Open bonnet and Driver side window.
- Ensure all doors are closed and remove key from the ignition
- Wait for 5 minutes, then disconnect the vehicle battery negative and wait at least 5 minutes. Don't open any doors or press any buttons.
- Reconnect the vehicle battery, wait a further 3 minutes (do not open doors).
- Switch on the side lights through the driver's window.
- Switch on the ignition only, don’t start vehicle yet and check system's functionality.
- With key still in ignition hold lock button on key down for 5 seconds.
- Remove key through window, then operate Central locking several times.
- Now open door and start the engine and complete the system's check.
- Failure to follow this procedure could result in incorrect operation of many BSI related items.
I give my time freely, but if anything has helped, you might wish to consider a small donation to the Forum, which helps keep it running without adverts - details here (plus you will get some free FCF stickers too):goggi10 wrote: 20 Oct 2018, 10:32 Thanks m8 i own you a dring as soon as i get nack im Serbia i will send you vie pay pal or western union to have a drink.
Donate Here
