C5 2.0 hdi 55 reg. Pulls left on braking.
mark230678
Unread post by mark230678 »
Me again
Weird one this.
Car pulls to the left when braking.
And to the right on accelerating
Not the callipers.
Mechanic says ball joints are fine. Changed o/s drop link because the near had changed.
Tyres are fine.
No wear.
Balanced 2 weeks ago.
Not had tracking looked at yet. But tyres are good.
Doesn't feel like tracking is out.
When I had it in the air yesterday checking power steering. I noticed a small amount of play in the strut. Like an amount of wobble.
My other guess is engine mount.
Cheers
Mark
Simple76
x 9
Re: C5 2.0 hdi 55 reg. Pulls left on braking.
Unread post by Simple76 »
Have you had the front brakes apart. Have seen many times where the front pads have been put in wrong. The pads have a notch which has to align with notch in piston for the handbrake mechanism.
x 2938
Sounds like a suspension fault to me.
MikeT
x 232
Unread post by MikeT »
I was going to suggest a front caliper issue as they don't seem to last well on these cars but as it pulls the other way under load, I changed my mind.
Don't forget the rear can have a steering effect too.
mark230678
What too look at. At the rear?
MikeT
x 232
My tracking centre waive the (under £40) fee if they find there's nothing to adjust.
x 2938
mark230678 wrote: 04 Oct 2018, 17:40 Me again
Weird one this.
Not the callipers.
Tyres are fine.
No wear.
Cheers
Mark
If you found this while the car was lifted that 'small amount of play' may be much more when under load, that's where I'd be looking before going on to anything else
Simple76
x 9
If there’s is movement in suspension normally bottom ball joint. However I would still check brakes.
mark230678
Why would the strut move / wobble slightly.
Anyone else had this. Searched here and googled. But no joy.
x 6945
Check the strut mounts, see if there is any movement if somebody turns the wheel lock to lock at the top of the mount inside the engine bay where the suspension sphere connects to the strut top / mount.
x 1463
Unread post by xantia_v6 »
The strut should be anchored by the mount at the top and the lower arm at the bottom. Which end has a wobble?
mark230678
Going into the socket at the top.
x 2938
If it's steering on acceleration and braking it suggests the bottom link bushes are worn and allowing the link to move back and forth.
x 1463
mark230678 wrote: 05 Oct 2018, 13:52 Going into the socket at the top.
That sounds like a problem, but I will let someone more familiar with C5 strut tops make a judgement.
x 6945
Here's the parts for the sphere / strut Mount - can you be a bit more descriptive of the issue? 'B' is the strut mount - so is this loose or turning?
