C5 Petrol - Engine Starting Wiring Issue
femtiolappen
x 4
Unread post by femtiolappen »
Where is the immobilizer cph on my Citroen C5 -04 and where is the soloniod on the engine?
The cpu is not working when cool outside.
femtiolappen
x 4
Re: C5 Petrol - Engine Starting Wiring Issue
Texton module alarm , but where is it in my car?
x 6947
I don't have your VIN for the C5 - post it here (it will be masked automatically).
I think you asked this before - there is no independent CPH or immobiliser unit on the C5 - the Engine Management Injection ECU controls the starting using the transponder code from the chips in the key / fob.
femtiolappen
x 4
Yes I have ask , car not start when cool outside , have to use a hairdrayer for start the car.
This is exactly the same problem like I have
viewtopic.php?f=3&t=50336&p=559818&hili ... an#p559818
I want to go around the problem , The ecu is new from citroën it cost 1500euro , but same s**t it not start when cold. Summer it working fine but 10 and down it will not start without heat.
femtiolappen
x 4
x 2938
I've got a new (old stock) Texton module sitting on my shelf here if anyone can use it, details on the label are:
TEXTON MODULE ALARME
9645500780
Index:A Date:F2
22481960 12/06/02
TEXTON ALM-01
Free gratis if you pay the postage.
x 6947
It's not the car alarm Gibbo :wink: It's a starting problem. The Xantia had a CPH immobiliser which I think he is referring to in that thread he linked to. The C5 does not have this.
x 6947
femtiolappen wrote: 02 Oct 2018, 12:19 Yes I have ask , car not start when cool outside , have to use a hairdrayer for start the car.
So are you saying you had a new injection ECU ordered - like item number 1 in the diagram?
Whatever your problem it seems electrical contact related to me - either a wire, or pin on a connector is not making proper contact in the cold - and only making the contact when heated up and expanded slightly. As the same think is happening with a new unit (if it was the injection ECU you had replaced) and you are having to heat it in the same area, then I can only assume that it is not the unit at fault, but a wire or one of the pins in a connecting block.
x 2938
GiveMeABreak wrote: 02 Oct 2018, 13:16 It's not the car alarm Gibbo :wink: It's a starting problem. The Xantia had a CPH immobiliser which I think he is referring to in that thread he linked to. The C5 does not have this.
I just noted the Texton name and remembered it was here Marc, still available if anyone can make use of it.
I've got a pile of bits and pieces sitting here that will soon have to go to the tip, some Citroen some for other makes.
femtiolappen
x 4
Yes no1 new from France replaced by Citroën , if the car stay in a hot garage the Lexia can connect to the ECU but if the car stay cool it can not connect and Lexia says ECU is looked , immobilizer fault and esp not working.
I not heating on the ecu beacouse it not help , I heat the main cablage if it -20 it take about 30min if it 6 it take about 5min , I have check all GROUND connections. I have open the cablage to but not se something.
When turn ignition on the yellow engine symbol not ligts up , only when i make cablage hot the symbol start light , then I can start the car.
Maybe I can make a 12v wire to that lamp? So 12v comes backway to ecu.
x 6947
Your issue has to be electrical - and will be somewhere in the communication between the wiring from the BSI to the engine fusebox and / or the Injection management ECU. I will have a look at the wiring diagrams to see what I have - that may be the best place to start as a diagnostic won't help if the ECU is not talking. Give me a few minutes.
femtiolappen
x 4
When 10-15c yellow engine light not working but with ignition on for 3min the lamp shine and I can start. 15c and up it will working just fine.
x 1472
Unread post by xantia_v6 »
Could the issue be with the immobiliser antenna by the ignition switch, or even the key itself?
x 6947
It's a good point, but the hair dryer in and around the engine bay wiring would seem to indicate the fault is there I suspect
femtiolappen
x 4
xantia_v6 wrote: 02 Oct 2018, 13:47 Could the issue be with the immobiliser antenna by the ignition switch, or even the key itself?
Citroën change the ring and make new codes , it not work.
