C5 2.0 hdi 55 reg power steering problem
mark230678
Have searched and searched on here.
I have a c5 diesel.
Took it out last week 100 miles. Parked overnight and came back to it.
Had fault light and stop.
Power steering faulty.
Thing is the power steering isn't faulty.
It works fine. Suspension works fine.
Breakdown came out. No problems found.
No codes
Told it was ok to drive and has been fine.
Mechanic also had a look. No problems.
No problems starting.
Any offers.
I have a c5 diesel.
No codes
Any offers.
- x 6961
Re: C5 2.0 hdi 55 reg power steering problem
Check the LDS fluid level.
Put the car on flat ground, engine running, put suspension to lowest setting and check LDS fluid levels are between the A and B marks:
mark230678
Is that the power steering fluid.
- x 6961
It’s contains both the suspension and the power steeering fluid. The systems share the same fluid reservoir. The fluid is called LDS and is exclusively used in the Citroen C5 and C6 hydraulic suspension systems and in the Power Steering systems of many Peugeot and Citroen vehicles.
mark230678
It looked ok when breakdown checked.
Will check again tomorrow.
No leaks noted.
Suspension works fine up and down on buttons and when loaded.
No leaks noted.
- x 6961
As I said, check the fluid levels according to my last post. The breakdown companies very probably don’t have the knowledge of how to check these systems correctly for fluid levels.
Sometimes raising the car through all height settings and lowering a few times at standstill is good to keep the hydraulics excercised.
mark230678
Fluid is at max level
- x 6961
Ok, just keep an eye on things - never overfill the tank - and ensure it's checked on the lowest suspension setting. It may have just been a glitch.
mark230678
Still has fault. And red stop light but no problems..
- x 6961
Ok, if the red stop light is on, there should be another warning bulb or message - can you confirm this. Secondly, are you using Lexia / Diagbox to read the codes? There will be a fault code if these warnings are on - but not all these can be read by aftermarket scanners - you need Lexia / Diagbos for a proper diagnosis.
I have to go out now, but will check back later.
mark230678
Hi. No other warning light. Just the stop light.
Power steering faulty comes up in centre display.
Generic code reader.
- x 6961
If you can get it on a Lexia, it will give you the fault codes, a generic reader won’t cut the mustard with PSA cars.
mark230678
Trying to find a lexia close by.
Even tried a bsi reset
- x 6961
Check out this post - this is a list of Lexia owners willing to help out - right at the bottom is a link to a Google map that shows the locations on there pinned for you:
viewtopic.php?f=19&t=56452
mark230678
Ta have messaged
