C5 x7 tourer rear bumper removal
JohnD
(Donor 2022)
x 72
Re: C5 x7 tourer rear bumper removal
Unread post by JohnD »
Paul-R wrote: 24 Sep 2018, 20:52 When I fitted the towbar part of the procedure involves removing the metal armature so that the bar can be bolted on.
Seven years ago a Witter towbar was fitted to my C5. I got a fitter to do the job on my drive so I was with him all the time. The only part that was removed was the bumper. Certainly no steel bar.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 1489
You can just about reach in behind the bumper with a screwdriver and lever down the clips which then allows you to pull the bumper out easily. They're not easy to get at, and it's easy to break them off. I think Citroen must have a special tool - you need something like a screwdriver with a curved blade on the side.
x 1940
This is mine.
Jim66a
x 9
Unread post by Jim66a »
Update: I have had the bumper off tonight. Came off easily following the instructions. Thank you to everyone that helped. (So far)!]
Jim66a
x 9
Good news is, My parking sensors are now working. Found a damaged sensor and the loom had been trapped cutting the wires. 20mins with the soldering iron and replacement sensor.. Job done.
Would love to retrofit front sensors.. anyone know if it can be done?
x 6945
You will need to replace the Parking Aasistance ECU as that will be a different part, plus the wiring loom to the rear, where the ECU is located, replacing or drilling out the bumper and then configuration of the BSI Jim. Plus there will be 6 sensors needed for the front, as the outer 2 on the left and right bumper / wing are also used for parking gap measurement system.
Jim66a
x 9
That sounds a little complecated and expensive!
x 6945
Yes not cheap - and I almost forgot - the relevant button on the dash for the parking space Gap measurement :-D
x 1940
GiveMeABreak wrote: 26 Sep 2018, 20:44... the relevant button on the dash for the parking space Gap measurement
I have one of those. I have never, ever, pressed it.
x 6945
I suppose it’s more use for those who’ve spent 20 minutes looking for a parking spot parallel to the main road and when you finally find one you’re just not too sure if the car will fit. But, remembering the activation sequence can be a faff if you’ve not used it often and don’t have the manual in the car 👀
Button pressed, indicator on for relevant side to be measured, speed under 6 mph, and no further away than 1.5 metres - simple!
Jim66a
x 9
I don't need the parking space assist, But it would be nice to know how far the front is away from things when parking up. Have the aftermarket sensors that just make a noise been tried?
JohnD
(Donor 2022)
x 72
Jim66a wrote: 27 Sep 2018, 10:50 Have the aftermarket sensors that just make a noise been tried?
My C5 didn't have sensors fitted but I've used an after market kit on the rear bumper and were very easy to fix. But they only work in reverse gear. Were you to put them on the front, they would be on all the time. Don't know whether it would matter.. 8-[
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Jim66a
x 9
I was wondering about how to switch them on. Maybe a relay that switches when the voltage rises (engine running).
x 1489
In this thread, David describes fitting front sensors to his 407: https://www.frenchcarforum.co.uk/forum/ ... 22&t=56160 ; then further down Sloppysod says he has fitted to his X7 - although no details. Might be worth a PM to see what he did. I don't know if the X7 has two options for the front - with / without the park assist; the latter might be possible with the existing ECU?
x 6945
As far as I'm aware Stu fitted and OEM original kit - not an aftermarket one. Each OEM system has a different parking assistance ECU. Jim, the front has to switch off at speeds in excess of 30 KMH on the OEM system.
If you are fitting an aftermarket one, the matter is irrelevant as they will have nothing to do with the OEM system and you cannot utilise an aftermarket system with the OEM system - they are not compatible and this is the case even with Citroen Aftermakret systems.
