C5 X7 Engine Management light
10051550
Unread post by 10051550 »
Hi Guys.
I have a 2011 C5 X7 2.0 HDi with the engine management light on
A quick check with my USB code reader reveals P2084
Could this be a sensor - any one else had this issue ?
I had given it a run down the Motorway in the hope that it might clear - but no luck
x 6957
Re: C5 X7 Engine Management light
If you have the DW10CTED4 engine, it will have the Delphi Injection system. That code is detailed below:
Fault CodeP2084
After sales description of the fault codeParticulate filter upstream gas temperature sensor: Voltage variation outside the tolerance
Description of the diagnostics
  • Electrical fault in the particle filter upstream temperature sensor
  • Variation in the temperature of more than 100 °C per second
Conditions of activation of the diagnosticsEngine running
Conditions of disappearance of the faultDriving with the engine hot for 5 minutes
Down-grade modes if fault presentDeactivation of the request for regeneration of the particle filter from the diagnostic tool
Switching on of the warning lamp and/or warning messageWarning lamp MIL
Main customer complaints likelyNo effects immediately perceptible to the customer
Suspect areas
  • Particulate filter upstream gas temperature sensor
  • Connector
  • Electrical harness
So on the basis of this code alone, it would seem your gas temp sensor is either faulty, or the electrical connections are. I will need your VIN to confirm this, as there's only so far the crystal ball can see. :-D
If it is the sensor that is faulty, here is all the info you need (pending VIN for confirmation)
Item 2 on the Diagram
Part No: 1618KP
Price £127.14 inc. VAT from Citroen
Thanks Marc
VF7**************[VIN obfuscated, can be read by forum staff] is this the correct part
10051550
Hmm can’t seem to post vin sorry , will check with dealer thanks again
x 1943
Don't worry about your vin post. The forum software "knows" a vin has been posted and obscures it so that it is hidden from general view. The Mods and Admins can see it though.
x 6957
Thanks for answering that one Paul I was tied up with XM sphere specs on another query! :-D
x 6957
10051550 wrote: 23 Sep 2018, 15:51 Hmm can’t seem to post vin sorry , will check with dealer thanks again
Yes correct parts as per my diagram - confirmed with your VIN.
Great thanks
ozzdownunder
Unread post by ozzdownunder »
Hi, I own a Citroen C5X7 MY11 HDI Vin VF7**************[VIN obfuscated, can be read by forum staff] - Also the ENGINE MANAGEMENT warning light is constantly on. Have disconnected the batt for a hour and when restarting it still comes on. It all sounds ok, nothing that I can hear or see is wrong. What could the problem be ?
Reason: Removed engine ref - not required
x 6957
You will need to get it diagnosed with Diagbox. There are any number of engine control system, emissions, or air & fuel faults that can bring this light on. There will be one or more fault codes active, so we need this to be able to help.
