Citroen Garage in the Midlands
vealg
Hi,
Can anyone recommend a good Citroen garage in the Midlands (preferably near Birmingham) please?
Delvey
- x 6
- x 5676
Re: Citroen Garage in the Midlands
Delvey wrote: 29 Aug 2018, 12:50 Not used personally however good reviews on Google
And a forum member.
Bick
- x 43
Ive used Mark and he does a great job - just say the site recommended you
oli_25_uk
I would recommend Dave at Citroen Specialists on the Pershore Road in Stirchley Birmingham http://www.citroen2k.co.uk He's looked after all mine (GSA, BX, XM,CX, C6 and now C5)...
OLIx
OLIx
markysimon
oli_25_uk wrote: 04 Sep 2018, 15:27 I would recommend Dave at Citroen Specialists on the Pershore Road in Stirchley Birmingham http://www.citroen2k.co.uk He's looked after all mine (GSA, BX, XM,CX, C6 and now C5)...
OLIx
I'm thinking of taking my S2 V6 XM to try and get the rough ride cured after already just replacing six spheres
Mark W
oli_25_uk
Dave's an honest guy who's been working on Hydropnumatic cits for decades - He'll know what to do - or be able to point you in the right direction...
OLIx
OLIx
markysimon
oli_25_uk wrote: 05 Sep 2018, 15:26 Dave's an honest guy who's been working on Hydropnumatic cits for decades - He'll know what to do - or be able to point you in the right direction...
OLIx
Thanks Oli, that's reassuring – I'm now booked in for Monday so finger's crossed!
Cheers – Mark W
- x 1746
markysimon
Finally managed to get there and was impressed by Dave's knowledge. He identified that the spheres sent by AEG were actually 40bar ones at the front which AEG had correctly identified as being for cars built just a couple of months after mine, which should've had 50bar. But he checked the ECU (was okay, adjusted the ride height, freed up a stuck height regulator... and the suspension/ride was improved, but not fully.
Citroen Specialists were very reasonably priced and Dave pointed out a badly rusted front NS sill by the jacking point (not me, honest!) that I need to get a plate shaped and welded onto, and explained why the NS rearview mirror doesn't dip when reversing – new one needed. So I'll definitely go back there even though it's a 90 min drive.
- x 6947
I don't have your VIN, but the XM V6 (ES9J4 Engine) built from RPO 7483 (5th May 1997) has the following sphere types and pressures, so depends when your build date was.
Reference Diagram
| Identification | Vehicle Type | Diagram Reference | Suspension Unit ID | Membrane: D: Desmopan U: Urepan M: Multi Layer | Volume (CC) | Pressure (Bars) | Damper (MM) |
| Main Pressure Accumulator | All Models | 1 | 96145672 | D Or U | 450 | 62 (+5, -32) | Without |
| Suspension Spheres (Front) | Saloon Estate | 2 | 962900048 | M | 450 | 40 (+5, -15) | 0,7 |
| Suspension Spheres (Rear) | Saloon Estate | 3 | 96222871 | D | 400 | 30 (+5, -15) | 0,6 |
| Front Suspension Regulator | Saloon Estate | 4 | 96281798 | M | 450 | 70 (+5, -25) | 1,25 |
| Rear Suspension Regulator | Saloon Estate | 5 | 96238950 | D | 400 | 40 (+5, -15) | 1,25 |
| SC/MAC Storage Battery (Anti Sink) | Saloon Estate | 6 | 96198613 | D | 400 | 50 (+5, -15) | Without |
- x 1746
Citroen list (Private Car Data, XM, 2001) front Hydractive corner spheres for Saloon/Estate V6
as 450cc / 40bar / 0.7mm
Saloon/Estates other than V6 listed as 450/50/0.8.
Citroen Parts show the same 450/40 spec for
3.0 24v 194
but for all other V6's
3.0 24v 200
2.9 24v 200
and 2.9 24v 170
the sphere spec is 450/50.
Citroen Parts do not show an RP date when spec changed.
40 bar will give a firmer ride than 50bar.
0.7 will give more movement damping than 0.8mm.
3.0 24v 194
3.0 24v 200
2.9 24v 200
and 2.9 24v 170
- x 6947
The above table I posted is from Citroen data and corresponds specifically for the ES9J4 V6 from that build date I mentioned. I didn't put together the others - but looks like there was confusion from aftermarket suppliers again.
- x 1746
You're right, Marc. Many aftermarket suppliers make assumptions about parts, and that certainly includes sphere types. Capacity and pressure is only two-thirds of the story as well, the final bit being damping aperture. Lost count of the 'compatibles' suppliers who don't even list it, so lord knows what you might be getting from them. Citroen's Private Cars document (2001, covering XM, Xantia and Synergie) is invaluable for nailing exact specs, capacities, etc of the cars' systems, and part of a series covering other PSA models too.
- x 6947
I agree Chris - unfortunately it's the same with many other aftermarket suppliers - their databases are so bad for parts and I do wonder what the unnecessary costs are in returns and wasted time delaying the jobs as a result. Always best to get armed with the kosher part numbers first and then one can always compare with the myriad offerings from other suppliers.
