C5 X7 Pollen Filter Replacement & Air System Clean How To
x 6957
Re: C5 X7 Pollen Filter Replacement & Air System Clean How To
elma wrote:That is expensive, maybe £50 worth of parts and £200 for 20 mins labour. I hope you got at least £300 out of the warranty.
I did James - I think I've had near £5k of warranty work done - (New Steering Rack, Crankshaft Oil Seal, rear Suspension Pipe, Labour on Clutch replacement, New Driver's Window Regulator, New A/C Condenser, New A/C Compressor, New Height Correctors that I can remember, plus all the labour and fluids this involved) - so not moaning on that score. But I never really looked at what was done before - so now I think I'll just be asking for an oil change and I'll do the rest!
elma
x 287
Unread post by elma »
Excellent value really then, that'll teach them to charge £10 a minute for labour.
milleplod
x 15
Unread post by milleplod »
Just wanted to say a big 'thank you' for this instructional! =D> Very helpful indeed - just changed mine (a new Motaquip one listed for a 407 was a fiver, delivered from good old fleabay)....15 mins from start to finish, I didn't even have to do the 'upside down in the footwell' thing, and I reckon next time I could easily shave 5 mins or more off that! The worst bit was not being able to feel my fingers afterwards....its bloody cold today! Image
Pete
Nocto Diuque Venamur.
x 6957
Excellent Pete, I'm glad it helped, makes it all worth the effort!
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Phew! That's been an energetic morning. Thanks Marc for the write up regarding the pollen filter. I've just finished doing mine. First time on this car. Previously I've left it to the dealer to do. But I hope I've made a better job of it than the Citroen workshop did. This is how the old one came out.
I guess I'm at the bottom of the league table. The job took me 90 minutes.. :oops:
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
adrianruk
x 5
Unread post by adrianruk »
Decide I would replace my cabin/pollen filter today. Easily removed thaks to Marc's excellent guide. Somewhat disappointed with what came out! A busy day tomorrow with airline & vacuum cleaner. I will make a better job of fitting it than the last bloke!!!
x 6957
Yep - when these go back in, you have to coax it in gently with a combination of manipulation at all the sides and the top / bottom whilst gently pushing it back, but without allowing it to bunch up in the middle, where you can't see it. Flat trim removal tools may help guide it in.
adrianruk
x 5
Job jobbed & relatively painless! Fortunately the filter had managed to keep the majority of the muck back & a brush & adapted vacuum cleaner tool sorted it all out. The new filter went in quite easily with a bit of a jiggle. I'm happy that it's intact & correctly fitted. One more job done! Thanks again for the help Marc. (still trying to sort a steering rack gaiter though!)
x 6957
Good job there.
Yakari
Unread post by Yakari »
Could someone tell me the size of this screw?
M4 or something else like that? :/
x 6957
It will depend on your build date:
For vehicles with RPO up to 12433 (23 November 2010), then it will be a Diameter 4.5 -15
For Vehicles with RPO from 12434 on (24 November 2010 onwards) then it will be a Diameter 4.5-20
citroC5
x 20
Unread post by citroC5 »
Very thorough and helpful thing to have this. Replacing any kind of air filter on a C5 X7 is sodding difficult, if you pardon my French.
Yakari
GiveMeABreak wrote: 29 Apr 2020, 18:43 It will depend on your build date:
Thanks for your answer.
i don't know what does RPO mean.
But i guess that the 4,5-20 is suitable for my C5.
x 3306
RPO is the date your car started construction. You can find the RPO number on a label typically stuck on a pillar in the driver door space. It will be 7 digits long, normally 5 numbers followed by 2 letters. The numbers related to the construction date, the letters refer to the factory. On my C5 it has the RPO 10045CJ.
https://bartebben.com/map/citroen-peuge ... umber.html
Jay-Bruce
x 280
Unread post by Jay-Bruce »
Just done this, thanks for the guide Marc. I put newspaper down to catch the leaves/bugs that came out, so didn't have to hoover the car. I know this is an old thread, the amazon link to the bomb no longer works, so I'll update it with links to the genuine PSA parts I got off eBay for it.
£8.49 for the Geunine Peugeot "bomb"
https://www.ebay.co.uk/itm/273841635488
£12.99 for the Genuine Gucci Peugeot Particle and Gas protection filter, Part No. 647945
https://www.ebay.co.uk/itm/234457134215
