Got some blackberry stains in my white paint. How do I clean it out?
kenbw2
(Donor 2017)
x 24
Unread post by kenbw2 »
The stains in question
I backed right into a blackberry bush on Sunday (today being Tuesday) and noticed this yesterday. Tried to clean it off today and most of it came off but I'm left with these purple streaks that won't come off. I assume it's soaked into the paint.
Been to one of those East European car wash places and they said they couldn't get it off. I don't really want to scratch the paintwork to remove it. Can I de-stain it somehow?
Ridiculous suggestion: bleach? Like, it's meant to be white, it can't decolour it? Might cause other damage though.
x 6945
Re: Got some blackberry stains in my white paint. How do I clean it out?
I think that's why paint protection and a regular wax is a must - I've just noticed a mass of scratches on one of my lower door areas - and very likely brambles from the country lanes. I used Mantis scratch remover, that very gently polishes the scratches out - but in your case, I would think the dye of the blackberries has been absorbed into the clearcoat / or paint topcoat depending on your finish.
Not sure if this works, but dug it up - measurements are American, but I've added the equivalents.
  1. Pour 1/4 cup (2oz or 59 ml) of water into a bowl, with 1/4 cup (2oz or 59 ml) of white vinegar. The vinegar will cut through the berry stains, while the diluted mixture will prevent the vinegar from damaging the car paint.
  2. Pour 1 tsp. of dish soap into the bowl also, which will help cut through the berry texture.
  3. Dip a cloth into the solution, then wipe over the stained area of car paint. Wipe in small circular motions, as you would to buff out the stain.
  4. Continue until you have removed the entire stain, then clean the area once more with fresh, clean water. This will remove any remaining vinegar or berry residue.
I'd be interested to see if it works :)
x 1746
Try Mer car polish - shifts most ingrained marks, although I appreciate this is a stain.
If the paintwork was porous enough to accept the blackberry stain, it might be porous enough to allow some Vanish stain remover (as used on fabrics) to do its job. Works on red wine, etc.
x 3296
I wonder if a clay bar might help here?
Sloppysod
x 396
Unread post by Sloppysod »
This stuffs removes virtually anything from paintwork -....................even your wax so you will have to re-polish afterwards =D>
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
kenbw2
(Donor 2017)
x 24
GiveMeABreak wrote: 21 Aug 2018, 14:10 I think that's why paint protection and a regular wax is a must - I've just noticed a mass of scratches on one of my lower door areas - and very likely brambles from the country lanes. I used Mantis scratch remover, that very gently polishes the scratches out - but in your case, I would think the dye of the blackberries has been absorbed into the clearcoat / or paint topcoat depending on your finish.
So I gave this a go last night. Wiped it on, rubbed it in and saw no improvement. Left it to soak for like 10 minutes and had another go. Nothing. Rinsed it all off and resigned myself to having stains.
Then I looked at it today, and it's all gone!
Woohoo
x 6945
There’s one for the books! Sound job.
x 1746
The paint is obviously porous: it took up the stain, and also that stain remover.
Quite common for cars painted in White not be be lacquered (at least no lacquer to peel!), and so no additional protective layer.
If it's completely gone, best to follow the advice and get some protective wax polish on the car.
x 1939
The phantom paint polisher passed by overnight?
x 1994
Unread post by Stickyfinger »
NEEDS a polymer sealer and then a hard wax and top off with a soft or liquid "polishing" wax.
