Citroen C4 grand Picasso thermal fuse
Karlos55
Hi my blower motor is on full power all the time, changed resistor next step is change thermal fuse. Anyone know location off thermal fuse.
- x 6956
Re: Citroen C4 grand Picasso thermal fuse
What's your VIN?, it may be integrated into one of the modules.
Karlos55
VF7**************[VIN obfuscated, can be read by forum staff]********
Reason: VIN Masked
Reason: VIN Masked
- x 6956
Ok so you have single Air Conditioning on this model.
I would suggest a diagnostic to obtain the fault code so that you can better ascertain the specific problem. There are quite a few listed.
Without a diagnostic to help pinpoint it, there's no way to know for sure whether the fault is in the control panel on the dash or the blower module itself.
I expect if there is any thermal fuse, it will be integrated into the control module.
| You only have parts: 1, 2, 3. 4. 6, 8 & 9 on your vehicle. No 3 is the Heater Motor Control Module. It is part number 6441 CE. | In this Diaggram, item 10 is the air heating resistance - so I hope you didn't change that as it won't affect the motor. | You have heater control variants 3 & 6. |
| This is the actual Heater Module Blower Module attached to the Blower Motor. |
Karlos55
I’ve swapped control panel on dash and module attached to blower motor from a friends car, his works perfect but in my car blower on full
- x 6956
So you really need to get Lexia on it to help determine where the problem is. You may have a problem elsewhere, like the engine fuse box.
