They changed the sparks and continued with the same symptoms.
Does anyone have an idea of what might cause the engine to fail and not have any errors in the ECU?
I need help with my C5 16v
- x 67
Re: I need help with my C5 16v
That's really annoying and surprising that's there's no fault code.
does the dash cut out when the engine dies?
![Think :-k](./images/smilies/eusa_think.gif)
Iain
1x '85 CX GTi Turbo s1 (metallic blue)
2x '85 CX GTi Turbo s2 t1 (metallic silver & grey)
'88 CX GTi Turbo s2 T2 (metallic light blue)
CX DTR T2 Safari (silver)
2x '96 Xantia Activa (Black & metallic green)
Iain
The problem now isn't to hang up.
The current problem is engine working with rattles and shake.
The dash doesn't turn off, the car continues to work but without force.
Today the coil pack was changed and the car is ok now.
Back on the road
Back on the road
As the problem was misfire due to the coil and there was no error in the ECU, is it possible that the knock sensor is faulty?
Update.
The problem was the ignition coil. The car now works normally.
Almost normal, he continues with hesitation as he accelerates.
I was measuring the voltage of the TPS as you can see in the film and I saw something curious.
The voltage drops when I'm opening the butterfly and goes up again. I don't think it's normal.
Reason: Fixed YouTube Links
Movie with a comparison between old and new TPS
Reason: YouTube link
