Front door speaker blown
This section is for General Enquiries or for Systems not Covered Above
MikeT
x 232
Unread post by MikeT »
Investigating a horrible occasional audio buzz, I find my front left door speaker has a 2-3inch tear in the cone.
Any recommendations for decent budget replacements? I do, albeit very rarely visit the F.Loud side of the volume when the mood/music requires it.
Are the rears the same fitment too?
Thanks in advance
x 6954
Re: Front door speaker blown
Aftermarket ones rarely go in exactly right, would you be happy with a replacement of the original?
The part number is 6562X2 for the loudspeaker and actually better value brand new from Citroen at £11.86 inc VAT!
I’ve seen second hand used eBay ones costing much more!
EDC5
x 130
Unread post by EDC5 »
£11.86 ??? :twisted:
When you consider their profit margin they're probably paying about £20 for the 4 main speakers in a car... that's disgraceful, glad I changed mine!
x 1751
Will put in a good word for Pyle Pro (PWM5 and PWM6, iirc), which can be had though Amazon.
Pyle Audio website has precisely dimensioned drawings and details of each.
Good price, and excellent quality.
x 6954
But when you consider ebay used ones are going for £10 each, I know I would buy a brand new one for £11.86 if I was wanting to keep the original speakers and not have to drill out extra holes and the like. There are some used pairs for £12-£15 quid - but I really wouldn't go for a used one as it's a false economy if it blows again in 6 months time :-D
MikeT
x 232
4 x 6562X2 cost me £49.78 (£10.37 ea plus tax).
x 6954
Gone for a full set then Mike!
MikeT
x 232
GiveMeABreak wrote: 20 Jun 2018, 14:53 Gone for a full set then Mike!
Might as well, at that price. Being paper cones, the rears will be tired, if not torn already.
MikeT
x 232
Picked the new speakers up today but the original rears are different. The plastic grill is grey, not black as per the fronts, and the fitments appear to be spaced differently (screw and lug holes). Shame because the left rear has two small tears in the outer cone too.
Interestingly, although I could clearly hear distortion on the front left broken speaker I had no idea the drivers-side front had an even bigger tear in the cone than the left. Probably because...
With the new fronts fitted, it is so much louder now I can only surmise I've been mostly listening to the radio (average volume level 10-14 when driving) through the tweeters on the dash all this time!
x 6954
Very odd - confirmed as the same part number Mike - so I think your 'tunes' have caused a 'speaker quake' and relocated the fixings! :-D
Time to give Black Sabbath a rest and opt for a bit of 'Hooked on Classics' maybe!
MikeT
x 232
I got that same diagram when I looked up my VIN on Service.Citroen, Marc - I don't have speaker #3 in my rear doors so assumed it's the wrong drawing altogether - perhaps for the saloons?
The original speakers are made in Poland by "ASK" and the rears also have different part numbers to the fronts as well as grill colour and fitment positions.
My invoice is hand-stamped "SPECIAL ORDER ITEMS: NON-RETURNABLE" so my next conversation with Pentons is going to be interesting!
x 1919
Notice on all the good albums - "Best played Loud"!
x 6954
Hi Mike - number 2 is supposed to be the correct part for both front and rear door speakers with the tweeters shown in the dash as at 1. I suspect that number 3 is / was for the JBL equaliser Amp possibly that had another speaker....
In either case, the standard ones should fit as the only other alternatives I can see under accessories are Pioneer ones that they offered.
MikeT
x 232
GiveMeABreak wrote: 22 Jun 2018, 18:23 Hi Mike - number 2 is supposed to be the correct part for both front and rear door speakers
In either case, the standard ones should fit.
Strewth, call me Mr Magoo. There's a redundant lughole I stupidly used that threw out the screwholes. All four speakers replaced now.
So to recap, all were torn along the outer part of the cone. Feels like some sort of foam, rather than paper? Will test the full sound later when I go shopping as ECO mode had kicked in.
x 6954
You do realise now that you've got your nouveau speakers, that your MPG is going to plummet with all that extra juice going into your tunes!
