C5 anti pollution
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5742
Re: C5 anti pollution
Post by GiveMeABreak »
Ok, so these remaining codes are pointing towards the Gas Temperature Sensor. P2033 says the voltage is higher than 4.98v for 2s and P2084 says the voltage has been incorrect for 1500ms.
So the common factor points towards either the gas temperature sensor itself, or the electrical harness.
Click to Zoom
The Gas Temp Sensor is Item (2) on the Diagram and the Part number is 1618PG (this is a replacement part number)
The Citroen price is £119.98. I've located this genuine one on ebay for £98.99 -
https://www.ebay.co.uk/itm/Lambda-Senso ... 2029648955
Grahambeveridge225
My Cars: Citroen c5
Post by Grahambeveridge225 »
Thanks mate
Grahambeveridge225
My Cars: Citroen c5
Does one sensor cover both the up and downstream as there's 2 faults stored?
C15 Romahome White
CX 20 Polar White
x 5742
Only one temperature sensor shown at 2. The diagnostics are reporting the wrong voltage values for various times on both the fault codes.
Grahambeveridge225
My Cars: Citroen c5
Thank you
Grahambeveridge225
My Cars: Citroen c5
Hey guys.nany thanks for all your help in my dreaded anti pollution fault.it was indeed the exhaust gas temperature sensor. All changed and now for some reason the car is much much smoother. Just waiting for the bill now
Post Reply
