RT4 software question
This unit is the RT4 and RT5 system and is made by Magneti Marelli
Main differences between RT4 & RT5 - RT5 has Bluetooth Hands Free, faster Navigation calculation and on C4 & C4 Picasso only, USB ports and a High-Res screen.
Bandit12
x 12
Unread post by Bandit12 »
hi guys
I've fitted a USB to my RT4, burnt all my music to media player then put it all onto a USB stick. Only issue is that some of the music wont play as its a wma file instead of MP3. Is there a software update or setting for the RT4 that will overcome this? Alternative is to work out which albums are wma then re-rip etc.
Any advice is appreciated
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
x 3296
Re: RT4 software question
When I use Windows Media Player to rip my CDs I have set it to the highest quality, and to MP3 format. I can then (for my van) copy the files to a USB stick and it handles them without any issues.
EDC5
x 130
Unread post by EDC5 »
The RT4 will only play mp3 as far as I'm aware, you can either re-rip the CD's in mp3 format or use iTunes to convert to mp3.
x 6945
That's correct, the RT4 doesn't support WMA files.
Bandit12
x 12
Thanks for that guys, was hoping for a simple fix and really unsure why some files are in different formats. No worries tho and I'll go through my music re ripping into MP3 :)
Bandit
x 6945
Some of the later units also support the Windows Media Audio format but not the RT4. I was going to suggest a converter, but to be honest it will be just as quick to rip again where you can choose your bit rate etc.
Bandit12
x 12
All sorted! I spent an entertaining afternoon re ripping my many cds n then syncing onto a flash drive. Works a treat. Many thanks :)
Florrynel
Unread post by Florrynel »
Check this out, software update + maps
https://www.ebay.co.uk/itm/Latest-2016- ... 3421770030
x 6945
I don’t think so! The pictures in that listing show an NG4 Navidrive 3D not an RT4 - another eBay fail where the seller doesn’t know the difference :roll:
x 1460
Unread post by xantia_v6 »
To be fair, the pictured disks appear to be RT4/RT5
x 6945
Caution needs to be exercised though, as invariably these will not be original discs, but copies and the risk of bricking a unit increases significantly, potentially costing £000s to repair.
