Any suggestions where to look first?
If I leave my X7 for about 3 days without using it, the fuel drains back into the tank. Which means I have a leak, however, the leak is not there when the engine is running as I would expect to see diesel everywhere so the fuel pressure must be closing the leak.
Or, does the X7 have a non return valve in the fuel system that could be letting diesel past?
Cheers
Leak - Air in diesel system -When Parked
Sloppysod
- x 392
Stu
- x 1751
Re: Leak - Air in diesel system -When Parked
Where petrol is normally pumped under light pressure from tank to engine bay, diesel is sucked out of the tank by the injection pump, so a leak of diesel may not show up. Air can be drawn in, but fuel will not leak out when the engine is running.
- x 695
Not to mention, air can leak through tiny gaps that liquid with surface tension will not, unless pressurised.
- x 3566
I think I'd be looking first at the little push-clip fixings (circled red) for the fuel pipes where they enter the fuel filter. These are the ones where you depress the coloured 'tag' and the pipe spigot then pulls off the filter fitting. They've always looked like a bit of a weak point to me. Check they are attached straight and level and not pulled at an angle.
Your filter may vary, but the pipe fittings (circled red) will basically be the same.
Also check the filter is fully tightened - the two parts circled blue should be touching which shows the filter has been tightened up properly.
Sloppysod
- x 392
Cheers, Guys,
Probably the connectors circled in red, they seemed very loose the last time I changed the filter so I put a tie wraps around them to make sure the white bits did not fall out !!
Ouch!....New pipe (filter to Pump) = £36, New Filter Housing £90
Stu
- x 2941
- x 1751
That will stop fuel draining back into the tank, but won't stop air getting in.
Most diesel fuel filters have a non-return (one-way) valve built into them already; iirc, Purflux has two.
Air-in-fuel needs to be sorted.
- x 2941
white exec wrote: 15 May 2018, 09:16 That will stop fuel draining back into the tank, but won't stop air getting in.
But they do fail and the add in valve is the cheapest way to fix it, I'm not sure the op has air in the fuel or it's just drained back and he 'thinks' it has.
- x 1751
Unless there's air ingress (even at the pump, or maybe further back), fuel won't be able to drain back, surely? - pipette action.
Sloppysod
- x 392
Bought a new filter house top which will cure one end including the syphoning back, next will be a fuel feed pipe (1579PV) unless I can get just a connector - any ideas?
Stu
