306 wiper not work correct.
fv43576
x 3
Unread post by fv43576 »
I have bought my new 306 HDI estate 2001, last week I knew the rear wiper was not work I can fix it. Today look on fuse in interior found a 20amps is missing, so I insert fuse, when I turn the stalk on first switch should be move all time but it do nothing, when I switch further for the water the wiper is coming on wiper 5 times then stop but the water is not function? #-o as I have notice the front auto rain sensor is not working but it works on manual speed one and two also front water jet is work as well.
Is this relation to relay on motor or motor faults or stalk fault or sensor?
x 6957
Re: 306 wiper not work correct.
Hard to say - possibilities:
The rear water hose may be linked or blocked.
The Light/ rain sensor may have been disabled in the BSI.
If you have the combined rain and light sensor, does it work with auto lights?
fv43576
x 3
Switch the lights on put rain sensor on auto nothing happened.
fv43576
x 3
I can hear the water pump working only front and rear sound dead likely pump fault leave this one, I am try to find the problem if it is stalk or the motor relay because the motor is work so that has got to be the relay on the motor.
x 6957
Ok, do you have your VIN handy?
fv43576
x 3
The rain sensor has work now! I remove the plug on the top of windscreen it was very rust on connector. One of three problem has solve. The rear jet water pump is dead with no resistor on multimeter but rear wiper still not response. The relay blue on the side of motor said 12v 2047029 should I buy this or the motor??? my VIN is VF3**************[VIN obfuscated, can be read by forum staff]
thanks
x 6957
I would opt for the pump first - very rare for the reverse wash stalk part to go on the Comms Unit, as it is used a lot less in comparison with the front I suspect.
I would test the pump first - here's the part number and new price if you need it
Part number (5) in the DIagram is PSA Part No: 6434 60
£55.52 From Peugeot inc. VAT
fv43576
x 3
GiveMeABreak appreciate! for the picture and the code.
Michel
Unread post by Michel »
Wow, £55 quid? The same thing (search for part number) can be had on eBay for £6..
x 6957
I just tend to put the official price up when I'm short of time - it's good for a comparison Mike and sometimes the dealer can be cheaper on some spares - but yes, there are cheaper alternatives out there. :-D
fv43576
x 3
Got a new pump from my local car parts for £7.49. I have fit it the rear jet it works but the rear wiper is come on only the second switch but the first switch do nothing!. The fuse are fine, the motor I took it off and put on 12volts battery it go nice smooth it has to be the blue relay fault?
fv43576
x 3
On Friday my local Autoelectric found wire has been cut in a half where the rubber hose between the body and tailgate. This is what cause the wiper not work on the first switch.
