Xsara Picasso
Ttwlr
Xsara Picasso
Unread post by Ttwlr »
What’s tgis part called and is it easy to fix please
x 1490
Re: Xsara Picasso
That's the damper / shock absorber. Shouldn't be too hard to change - if you can get the bolts undone. You should really change both to avoid wrecking the handling.
x 6945
Re: Xsara Picasso
errr... that's your suspension strut and a very sorry one it's looking too! :-D
I've rotated it to make it clearer to see. Easy enough job for a garage to do - but you'll might need a shock absorber compression tool in order to get the damper on.
x 1490
Re: Xsara Picasso
It's just the damper Marc - these use torsion bars for springs. No special tools, just put a jack under the trailing arm to take the weight when you take the bottom bolt out.
x 6945
Re: Xsara Picasso
Even better then! :-D They do go on about using some compression tool and a dummy damper to set the height - but as you've obviously done a few of these, that's one less thing to worry about. :wink:
Ttwlr
Re: Xsara Picasso
Cheers people, both mines are the same 😠
So should I be able to do them at home or do I need a garage to do em?
Are they all the same or do I need part No
Ttwlr
Re: Xsara Picasso
Seen some dampers without the ruber gator, will these fit mine ?
Put part number in ebay and nothing shows up
Bick
x 43
Re: Xsara Picasso
Unread post by Bick »
GiveMeABreak wrote: 03 May 2018, 16:49 Even better then! :-D They do go on about using some compression tool and a dummy damper to set the height - but as you've obviously done a few of these, that's one less thing to worry about. :wink:
Thats when setting the ride height or the rear axle - the torsion bars have some adjustment.
Bick
x 43
Re: Xsara Picasso
Ttwlr wrote: 06 May 2018, 06:15 Seen some dampers without the ruber gator, will these fit mine ?
I would use some with the gators on as they are there for a reason - there is a lot of Cr*p gathers around them - try GSF parts
Ttwlr
Re: Xsara Picasso
Being a novie is dampers & shocks the same thing ?
Been looking for cheaper ones but confused with seeing shocks not dampers 😂
x 2938
Re: Xsara Picasso
Ttwlr wrote: 06 May 2018, 08:58 Being a novie is dampers & shocks the same thing ?
Interchangeable names , back in the earlier days they were called shock absorbers then we 'Americanised' and called them dampers, old timers like me still call them shocks.
Ttwlr
Re: Xsara Picasso
Cheers gibbo that’s clears that up,
Ttwlr
Re: Xsara Picasso
Are the perished gators a MOT fail ?
RobinMasters
Re: Xsara Picasso
Unread post by RobinMasters »
Gibbo2286 wrote: 06 May 2018, 09:30
I think this is the one instance where Americans have changed English for the better, as damper more accurately describes what they actually do.
x 5672
Re: Xsara Picasso
RobinMasters wrote: 07 May 2018, 18:34
True enough but they are still not forgiven. :twisted:
"Shined" is the one that gets me to grate my teeth. I read mainly on a Kindle and it is ubiquitous there :(
