Wipers won't work on fast speed
Ange321
Hi i have a peugeot 206, 04 reg
The front wipers work fine on the first and second settings the intermediate and the slow speed, but when i put them on the third setting the fast speed they dont work, they just compleatly stop anywhere on the windscreen,
- x 6956
Re: Wipers won't work on fast speed
Do you have your VIN, so we can ascertain options and specifics.
Ange321
Can i put the vin number on here, could my car get copied by that, i thought the vin was a number set just to the car,
Its a peugeot 206, 04 registration, hdi diesel, two door with hatchback
- x 6956
Yes just send a PM, I usually mask it once you have sent it.
Ange321
The car is up the road at the min and its raining very hard, can we work it out without it, and to be honest im not even sure where to find it.
Ive looked at the fuse under the bonnet next to the battery and it seems there is only one fuse and it seems ok
- x 6956
PM your reg then. I need to consult the database as to specific options and to consult the wiring diagrams.
- x 6956
Ok, so you have the 1.4 HDi 3 Door, without the rain / light sensor option.
So first off, you really need to get it diagnosed with Peugeot Planet 2000 - that may provide a fault code that can point to the problem, so I would encourage this first.
It won't be a fuse as the wipers are operated through all speeds on the same fuse and you are getting them working on intermittent and slow speeds.
The relay is usually contained within the body control module and these are not generally accessible.
I would check the connector near the wiper motor - remove and clean the connector and make sure there is no crud / rust on the pins or the wires - use a bit of electrical contact cleaner if necessary.
Next try the BSI reset as below and don't skip any parts - it won't cost anything and although you say you have tried, make sure you follow it.
There is a supplier of replacement reconditioned and new Comms units here and I have linked to the part number for you.
http://www.peugeotpartsforsale.com/inde ... h=96787362
Steering Wheel Control Module Part Number: 6239 AE or the replacement part number: 96787362
- Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
- Ensure all doors are closed and remove key from the ignition.
- Wait for 3 minutes, disconnect the vehicle battery and wait for 5 minutes.
- Reconnect the vehicle battery, wait a further 2 minutes (do not open doors).
- Switch on the side lights through the driver's window.
- Switch on the ignition and check system's functionality.
- Hold lock button on key down for 10 seconds.
- Remove key open & close door test central locking system.
- Start the engine and complete the system's check.
Ange321
I tried resting the bsi but no luck.
I will try to find the connector near the motor, it seems hidden and very hard to get to
- x 6956
Here are the diagrams of the wiper assembly and the area showing the scuttle - which might help you with removal
Click to Zoom Diagrams
Ange321
Could it be the motor broken, or would that not work on any speed if it is broken.
- x 6956
If it was the motor - then it most likely would be stopping / starting at random spots on any speed as it is under the same load while on the car during a wipe cycle and the speed shouldn't make any difference.
Ange321
Took a while, but i checked all the conecters to the motor, they all look ok and clean.
Could it just be the switch stalk, rather than the whole comms unit. That would cost so much, i hopeing its something easier.
- x 6956
I'll have a look at the wiring in a second for you - but I really recommend you get it to somebody (possibly a member on the Forum here) with a Peugeot Planet Diagnostic. That will a) confirm if there are any fault codes, and b) allow an actuator test of the wiper motor that should determine whether the Comms 2000 unit is at fault or not.
I agree it is a bit costly replacing the Comms Unit - a second hand one may be a solution - but again you may be buying one that could fail anytime soon too.
So I'll have a look at the wiring in a bit, but whilst I'm doing that, have a look at the Lexia locations thread here - this lists members with diagnostics that are willing to help and their locations - there is a ling to a Google map at the end that shows their locations on the map. Send one of them a Private Message / Email of they have allowed this and see if you get a response. Be aware that not all the members are active all the time though....
Of course the motor itself could be shot - so testing it with the diagnostics will help.
- x 6956
So here is the wiring diagram for the motor.
As you can see the relay for the wiper motor is contained within the Body Control Module / Engine Fuse Box Unit (BM34). - so if the relay - then you might be looking at another fuse box module or the Motor.
So getting it diagnosed is really your best bet as you could end up replacing parts you don't need to.
| 500: Low speed motor command 501: High speed motor command 503: Engine fixed stop command 5265: Front windscreen wiper relay output BM34: Engine Slave Unit 34 fuse(s) |
Ange321
Thank you for all your help, took it to a garage it was the moter that needed replacing
