Magneti Marelli rt 4 problem
This unit is the RT4 and RT5 system and is made by Magneti Marelli
Main differences between RT4 & RT5 - RT5 has Bluetooth Hands Free, faster Navigation calculation and on C4 & C4 Picasso only, USB ports and a High-Res screen.
Bibiqn
Re: Magneti Marelli rt 4 problem
Unread post by Bibiqn »
This device on the picture downloaded from C6 2007
x 6945
Yes that was the unit in later C6 models. I had the RT3 in my 2005 C5. You have to also think of the screen on these too as they need to be compatible. Try and match the head unit with the same model if possible, or get a quote for repair.
Here’s a link to some repairers, one in the UK and the other in Spain who does these:
viewtopic.php?f=10&t=54055
Bibiqn
GiveMeABreak wrote: 28 Apr 2018, 15:21 Yes that was the unit in later C6 models. I had the RT3 in my 2005 C5. You have to also think of the screen on these too as they need to be compatible. Try and match the head unit with the same model if possible, or get a quote for repair.
I read for this service.But its very far from Bulgaria and much expensive.delivery to spain and back.and for repair .
x 6945
Get a quote, it may be less than you think even with delivery using a courier service. Probably cheaper than a new unit or good second hand one.
Bibiqn
Looks like same.
My screen
My screen
C6 screen
C6 screen
x 6945
Unfortunately I can't see the code but the number beginning 9661626.... is the model number of the screen.
Bibiqn
GiveMeABreak wrote: 28 Apr 2018, 15:40 Get a quote, it may be less than you think even with delivery using a courier service. Probably cheaper than a new unit or good second hand one.
I find this device in the picture second hand
For 100euro
x 6945
The screens all 'look' the same, but they are not - the part numbers are different between your one and the C6 9661626***
Your screen starts 9661236080
The screens actually contain an ECU so need to be compatible with the Head Unit
Your current problem is with the Head Unit not the screen though. :-D
Bibiqn
GiveMeABreak wrote: 28 Apr 2018, 16:21 The screens all 'look' the same, but they are not - the part numbers are different between your one and the C6 9661626***
Yes.My screen is work.But i cant find same device rt 4 from c4 picasso.i find from C6 .and you now say me rt4 from C6 not compatible with my screen.
x 6945
What I'm saying is the screens are not the same in the pictures. You can rarely mix and match these units.
What is your VIN? I can see what the screen code is for your system.
Bibiqn
GiveMeABreak wrote: 28 Apr 2018, 16:51 What I'm saying is the screens are not the same in the pictures. You can rarely mix and match these units.
Bibiqn
Here you go.
x 6945
Ok, so here is your problem - Citroen only sell the complete instrument panel (over £3100!!!), so very expensive. they don't show the separate screen, so I can't get a code for that.
I would forget about the screen completely and just get an RT4 that is THE SAME as the one in your Picasso, like this:
https://www.ebay.co.uk/itm/RT4-radio-na ... Sw1utaz8M0
The earlier units are quite hard to get hold of as you have found out, which keeps the price high.
I simply cannot say whether the C6 unit is compatible with the C4 Picasso for sure - because of the different vehicle architecture, screen etc. and a bit of a risk to take.
EDC5
x 130
Unread post by EDC5 »
GiveMeABreak wrote: 28 Apr 2018, 14:27 Guys this is probably NOT compatible with the C4 Picasso. That is an older system. The RT4 that went into the C4 Picasso is similar to the RT4 used in the early X7.
Yes, the RT4 in that picture is much larger than the single DIN variant of the RT4.
x 6945
Good point - size matters!
