C5 X7 Electronic handbrake cable
Qube90
Hi
Does anyone know where i can buy new parkingbrake cables (Electronic parkingbrake) for a Citroën C5 2010.
- x 1488
Re: C5 X7 Electronic handbrake cable
Welcome!
Officially the only way to get the cables is to buy a complete motor unit, which costs 970 GBP in the UK
This has not been explored yet, but I can see this starting to be a problem here in the UK with rusting cables. It might be possible to strip the unit, and then get a specialist to make up some suitable cables. Or it might all be encased in plastic and a no-go!!
- x 6945
Yes, a complete unit on the X7.
EDC5
- x 130
That's a bit scary
is there any rustproofing you can do to the cable to stop this from happening?
- x 6945
The cables are for the most part encased in sleeves, and the unit itself has a finite number of activations, after which it will need replacing anyway, so I wouldn’t bother trying to take it to bits and transplant bits; probably better to source a second hand unit if it does go, as that’s the only way you are going to get the cable anyway.
- x 1996
A guy on a Turkish FaceBook (C5) Group dismantled and fixed one......I do not have the link sadly.
milleplod
- x 15
There's no specific mention of Citroens on the website, but these guys might be worth a try - http://www.parkingbrakerepair.com/index.html.
Pete
Pete
Nocto Diuque Venamur.
Qube90
Thanks. I talked to "parkingbrakerepair" but they didnt have any cables to Citroën
- x 6945
Here's the inside of the unit for those interested:
Not shown is the separate control and cable for the manual release mechanism.
| (1) Automatic electronic parking brake. "a" The reduction motor "b" engine "c" Rotation sensors "d" Connector "e" Electric parking brake rear right secondary cable "f" Manual release cable "g" Release mechanism (Manual) "h" Splined shaft "j" Threaded pin "k" Integrated force sensor "l" Electric parking brake rear left secondary cable |
| Tightening Action | Slackening Action |
| EPB ECU controls motor "b" in application direction "A" | EPB ECU controls motor "b" in release direction "B" |
| Force provided by motor "b" is reduced & sent by reduction motor "a" to splined shaft "h" | Force provided by motor "b" is reduced & sent by reduction motor "a" to splined shaft "h" |
| Splined shaft "h" & threaded pin "j" are linked by interior thread of splined shaft "h", the rear left | Splined shaft "h" & threaded pin "j" are linked by interior thread of splined shaft "h", the rear left |
| Secondary cable "l" is linked to threaded pin "j", the rear right secondary cable "e" is linked to splined shaft "h" | Secondary cable "l" is linked to threaded pin "j", the rear right secondary cable "e" is linked to splined shaft "h" |
| The rotation of splined shaft "h" in application direction inserts threaded pin "j" in splined shaft "h", which draws in right & left secondary cables | The rotation of splined shaft "h" in release direction extracts the threaded pin "j" from splined shaft "h", which distances right & left secondary cables at "B" |
| The drawing in of right & left secondary cables applies rear brake calipers | The distancing of right & left secondary cables at "B" releases rear brake calipers |
- x 1996
Yep, a simple lever and cable is just too complicated
- x 6945
You should see the troubleshooting info - plus 20 pages!
- x 1459
It would be worth contacting Speedy Cables https://speedycables.com/about/ who do make/repair custom brake cables.
- x 1488
Yes, looks to me like it would be amenable to being opened up and getting SpeedyCables to make up some new ones. Nothing lost if one or more cables is shot anyway!!
KennyW
- x 165
Out of curiousity, can the electric handbrake be changed to mechanical
Before anyone says anything he's rolf
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 6945
Yes, that's about it Kenny
- only the Hydractive Suspension Models had an EPB, but the central console is different to accommodate models with a manual brake - so all the hassle of changing the trim and reprogramming the BSI / ESP System etc.
The EPB's master control is the ESP ECU, with the EPB ECU being the slave - but control can be passed from one to the other in certain conditions. So a lot more involved that just mechanics.
