Sensors to 605
tjensen
Sensors to 605
Unread post by tjensen »
Where to locate the flywheel sensor and crankshaft sensor on the Peugeot 605. I can not find these.
x 6956
Re: Sensors to 605
Hi and welcome.
As we don’t know your engine or specs, please can you post or PM your VIN so we assist further.
tjensen
Re: Sensors to 605
Thanks. It`s a 2,0 l turbo aut. 95 model gasoline.
x 6956
Re: Sensors to 605
That doesn’t help. We need the VIN. There are at least 3 versions of the 2.0 petrol!
tjensen
Re: Sensors to 605
OK. I found all these numbers. Can you use on of them?
Kjøretøy PEUGEOT 605 VF3**************[VIN obfuscated, can be read by forum staff]
Understellsnummer VF3**************[VIN obfuscated, can be read by forum staff]
Typegodkjenningsnummer 01260041994
x 6956
Re: Sensors to 605
The only valid VIN is the one ending in 832 - the last one is not valid. So this one is the
605 4 DOOR SALOON 2.0 i 8v TE Auto gearbox 4 with XU10J2TE engine.
Information is limited I'm afraid, but hopefully the following diagram, although not detailed may help you identify the location of the sensors:
(4) - Water Temp Sensor
(8) - Acceleration Potentiometer
(9) - Speed Sensor (2 way)
(10) - Speed Control Housing
(2) - Engine Speed Sensor
(7) - Engine Pinking Sensor
(11) - Intake Air Temp Probe
