LIMP MODE 07 1.6HDI BERLINGO VAN
SEATON95
Unread post by SEATON95 »
:rofl2:
My Berlingo van goes into limp mode as soon as I hit 60~65mph.
I’ve had the turbo and injectors changed.
Can anyone solve this problem.
Thanks.
EML CODES
P2142
P0409
P2111
P1351
P0234
8-) 8-)
Reason: Sentence case
x 6955
Re: LIMP MODE 07 1.6HDI BERLINGO VAN
Can you advise us of your VIN, as that will help identify the exact engine and equipment fitted.
In the meanwhile, indicative codes are:
CodeFault
P2111Mixer butterfly position copy signal : Butterfly stuck during post operation
P0409EGR electric valve 1 (rear) position fault : Poor contact
P1351Pre-heating relay circuit : Relay controlled and plugs never supplied
P1351Fault on the pre-postheating relay circuit : Relay controlled / plugs not controlled
P0234Boost pressure regulation : Air pressure above the reference value
P0234Turbo pressure regulation : Pressure higher than the reference value
P0234Turbo pressure signal fault : Turbo pressure measured too high / Turbocharger pressure reference value
I would check they connected all the solenoid vacuum hoses back up properly when the turbo was changed - and to the air doser. These and the EGR valve issues would possibly point to the vacuum circuit that supplies all these.
SEATON95
x 1484
Only the turbo is vac on this engine. P0240 will be causing limp. On a 110 it could be the solenoid, vent filter, or turbo vanes, not sure about the 90s
x 6955
This is the BERLINGO VU (M59) SHORT VAN '600' 1.6 HDi 75 Manual gearbox 5
So the HDI 75 engine.
You didn't mention code P0240?
So here's the Turbo Vacuum circuit to check - part 1 is the solenoid:
Click to Zoom Diagram
x 1484
Mis read it, I meant P0234 - it's the overboost one anyway!
SEATON95
Soon as I hit 60mph or over 3k revs it looses power new injectors and new turbo checked the vaines clear so going to change the solonoid and see if that's helps
