thank you sir.
so , IMO, I need 7715 and 6606 and there's an extra loom runes from PSF1 (9 and 10) to each light and a loom run from the bsi to 7715 (assuming thats the suspension pump) and 6606 is the light ecu.
is 78-- related to tyre sensors (I know it says esp)?
most looks at my unprofessional glance to be very similar; ofc mine doesn't have tyre pressure sensors.
Wiring diagram for xenons - 2007 mk1 facelift C5
Harlequin
- x 24
- x 6956
Re: Wiring diagram for xenons - 2007 mk1 facelift C5
Some extra info - Flow Chart for Directional Lighting
| Directional Lighting Flow Chart |
| Single arrow: Wire connection, Double arrow: LIN connection, Triple arrow: Multiplexed connection |
| Code | Description |
| BSI1 | Built-In Systems Interface |
| BSM | Engine Fuse Box |
| CV00 | Switch Module At The Steering Wheel |
| 0004 | Instrument Panel |
| 1320 | Engine ECU |
| 1630 | Automatic Gearbox |
| 2610 | Left-Hand Headlamp |
| 2615 | Right-Hand Headlamp |
| 5007 | Rain/Brightness Dual-Function Sensor |
| 6606 | Directional Headlamps ECU |
| 7715 | Suspension ECU |
| 7800 | ESP ECU |
| N° | Description | Power consuming equipment | Connections |
| 1 | Engine running status | Directional headlamps ECU | CAN |
| 2 | Gearbox ratio engaged | Directional headlamps ECU | CAN |
| 3 | Status of the dynamic lighting. Status of the automatic height adjustment | BSI1 | CAN |
| 4 | Engine running status. Gearbox ratio engaged (if automatic gearbox). Reverse engaged (if manual gearbox). Vehicle speed. VEHICLE RIDE HEIGHT. Steering wheel angle sensor information. Status of the lighting controls | Directional headlamps ECU | CAN |
| 5 | Supplier’s specific network | Headlamp | LIN |
| 6 | Concealing flaps control. Additional halogen main beam headlamps control | Headlamp | All or nothing |
| 7 | Request for switching on of the directional headlamps. Main beam/dipped beam headlamps request (concealing flaps) | BSM | Body CAN |
| 8 | Directional headlamps fault status | BSI1 | Body CAN |
| 9 | Main beam headlamps fault status. Information on brightness. Steering wheel angle sensor information. Status of the lighting controls | BSI1 | CAN |
| 10 | Directional headlamp height adjuster fault. Request for switching on of the directional headlamps. Main beam/dipped beam headlamps request (concealing flaps) | BSM | Body CAN |
| 11 | Information on brightness | BSI1 | Body CAN |
| 12 | Direction of rotation of the steering wheel. Initialisation of the steering wheel angle sensor. Status of the lighting controls | Directional headlamps ECU | Body CAN |
| 13 | Light indicator lamps control | Instrument panel | COMFORT CAN |
| 14 | Status of the dynamic lighting. Status of the automatic height adjustment. Directional headlamp height adjuster fault | BSI1 | CAN |
| 15 | Deactivation of the dynamic lighting. Status of the dipped headlamps. Steering wheel angle sensor information. Information on brightness. Status of the lighting controls | Directional headlamps ECU | CAN |
| 16 | Vehicle ride height information | Directional headlamps ECU | CAN |
| 17 | Vehicle speed | Directional headlamps ECU | CAN |
OlegR
What's the end of this story?
In my setup, I don't have only the 6606 Directional Headlamps ECU
having experience converting my old '86 BMW from ECU Motronic 1.0 to 1.3 from a '94 7 series, looking at the diagrams it's doable.
Need to wait for the summer and find the missing ecu+connector, and the diagram for my car, and will try it.
