Lexia unable to communicate with ECUs
x 6947
Re: Lexia unable to communicate with ECUs
A couple of things:
Yes, the Diagbox uninstaller only installs the applications from the paths it originally installed to - the standalone version may well use a different folder structure.
Second, before changing anything - I've found a similar thread on C6 Owners that seems to be similar to your own situation, and this may have been down to the soldering in the VCI where the interface connects to the cable - it seems like a lot of the solder joints had come away....
http://c6owners.org/plugins/forum/forum ... .php?25230
I'm not quite sure of the outcome as he doesn't report back, but seemed to have the issue you are having AFTER re-soldering.
I think it would be wise to have a look inside and see - if the unit is out of warranty there is nothing to lose by opening it up. That and also trying it out on another PSA vehicle would seem like the sensible thing to do before doing anything else software related. So, either test your unit on another PSA car to see if it can communicate and / or get someone with another unit to check on your vehicle before you go any further.
sonoramicommando
x 5
Unread post by sonoramicommando »
I did visually inspect the VCI innards and it looked ok (I'm an electronics dummy but I think I can spot bad solders).
I've been meaning to test out it on someone else's car - there is a 405 I can try it on, but it's some distance away so I just need to get around to it. There is another fellow with a 207 but he doesn't trust me with it... :(
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
harryp
(Donor 2022)
x 73
Unread post by harryp »
Is there a list anywhere of the relative firmware and associated versions of the diagnostic software and to which vehicles they apply?
I ask as I have to use an older VCI for my Xantia (and incidentally my son's Peugeot '06 soft top) and the latest VCI for our '63 plate C4 Picasso, both running on V7.58 . Does seem very strange that the "new" VCI will not talk to the older vehicles. Is this because the firmware version is carried/used by the VCI?
Thanks and regards,
Harry
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 6947
Hi Harry, because these are clone interfaces, there is bound to be some issues with the different versions. normally as you know Lexia will automatically launch for older vehicles and Diagbox for later cars. The Diagbox software updates the firm as necessary for the relevant version of Diagbox being installed.
However, for older cars, the VCI may need a lower firmware version for the VCI. My own unit launches Diagbox for my C5 X7, ut launches Lexia for the 07 C3. I am running Diagbox V7.62 IIRC and this is where it will remain at present. I do not need to change the firmware manually, as everything just works between the vehicles.
As not all the VCI interfaces are made equal, :-D there may of course be a double whammy with the hardware capabilities too.
Back to your question though, it doesn’t quite work like that in terms of what versions for what cars. Basically the firmware may stay the same for several incarnations of Diagbox, and will only change when there is a newer vehicle perhaps with a newer BSI or newer vehicle software, or newer ECUs on the vehicle, requiring the VCI interface to be updated in order to talk with them. Normally the interface is backward compatible though, except where there may be an older VCI clone that may need an older firmware version to operate.
The added problems are that with each new version of Diagbox, there are bug fixes to correct problems sometimes in the previous release, and sometimes in even earlier releases. So the golden rule here is not to keep updating unnecessarily, as you may end up continuously updating to fix previous problems - none of which may affect your own car. Plus of course we know that the tele-coding functionality is diminished in each later version from about 7.65 on as it moves to internet configuration, which we can’t do on our clones without payment to PSA for server access.
I did start to provide a list of changes between versions, but stopped at the versions when they started loosing functionality. The change log is on the Wiki here:
https://frenchcarforum.co.uk/wiki/index ... 9/7.06_On)
x 2938
That last link Marc pops up a 'file not found, not on this server' message.
x 6947
Give it a while Gibbo - Mike may be doing something on the Server - the Wiki isn't available at this moment, but should work when it is back up :-D
x 1472
Unread post by xantia_v6 »
It should be back now, I was doing some server maintenance, and inadvertently disabled the url routing for the wiki.
harryp
(Donor 2022)
x 73
Marc, thank you for your response. What you are saying is that the software automatically updates the firmware, which on older vehicles may well put it out of the "range" of the ability of the newer VCI to actually communicate. That will make sense sadly; I had assumed (never do that) that the newer VCI would satisfy all, not realising that the software auto updates the firmware with the results I am seeing, or not as it happens.
Thank you again!
Regards, Harry
Regards, Harry
x 6947
Hi Harry
It is a distinct possibility. Diagbox will install the appropriate version of firmware (up or down) according to the table below Harry:
Click to Zoom
harryp
(Donor 2022)
x 73
Hi Marc
Excellent little table - all explained very succinctly.
Remembering back 6 years or more when I bought my first Chinese clone, "Scary" installed it remotely as the DVD sent was corrupt.... The VCI was not recognised and he had to lower the firmware so that it would run. I had to smile as the "only a few minutes" turned out to be over an hour. Good job I had no idea what he was talking about then :lol: . (not that I am much better now :lol: )
Once again, thank you for your expertise.
BTW I am trying to reload the Service.Citroen via the iso file disk images. Tried on Win7 and the program hung on image3 so left it overnight. Appeared to have finished by morning but would not open with error msg implying that file was corrupt.
Then tried it on Win 10 and none of the Disk Images will open. now running chkdsk as admin and hope this sorts out the problem, if any....
Thanks again and regards, Harry
Regards, Harry
x 6947
Hi Harry, those are notoriously hard to install on some systems and the VIN lookup no longer works by the way, since PSA have integrated all marques to the online version only.
pauliebear21
Unread post by pauliebear21 »
I cant get my Lexia to communicate with any of the ecus in my C8. No.dialogue. help!!
x 6947
What version of Diagbox do you have installed first of all?
Rhothgar
(Donor 2026)
x 222
Unread post by Rhothgar »
Just pre-empting any Lexia issues for Saturday and reading through some threads that may help.
I have 7.57 installed and presumably the Lexia has auto-updated online to whatever version of firmware it is now on. This is on a Rev B board.
Can you tell me if this will even read my Xantia 2.0 HDi or will I need to downgrade the firmware of the Lexia?
x 6947
Possibly. DON'T let it connect to an active internet connection, or it will deactivate and possibly block your unit.
Firmware updates are not completed online - they are installed automatically when you upgrade the version where it is necessary. Some firmware versions will remain for several updates.
