Newbie C5 owner
derk19601960
x 3
Newbie C5 owner
Unread post by derk19601960 »
Newbie to the site and C5 owner, been a few years since owning a Citroen, previously had 2 BX and a ZX many moons ago, all diesel. Recently purchased a C5 Tourer 1.6 hdi Nav+ with 128500 on the clock, as I only do 30 miles per week, then 200 mile trip once a month, I thought this would do what I needed it to. 1 owner from new, full service history with all receipts for previous work, also came with 12 months MOT, serviced by garage and 12 months warranty, for MOT it had pads and discs all round.
After first trip it had a misfire/stutter every now and again, garage replaced the EGR valve, according to ECU fault when plugged in this was causing it, picked car up drove 20 miles misfire/stutter still there, now there replacing the Air Mass Meter, both out of their pocket, cant fault them upto now, treated the same if I had spent 20k not 3k.
The thing bugging me the most is tailgate wiper, it works when it wants plus squirts screen wash every time, when screen wash frozen in pipes, I can hear the pump running, Anyone any ideas or solutions to this fault, I havent asked the garage yet to see what their response to this will be, Items not covered under warranty unless they break, same as most warranties.
Ive had a browse on site cant find the answer Im looking for.
Thanks for reading, all answers much appreciated.
x 3296
Re: Newbie C5 owner
Hi, and :welc: to the French Car Forum. If you are looking for a good independent Citroen garage you could do a lot worse than call into Savoy Garage. Please accept my apologies for the fact I cannot offer any other advise.
https://www.frenchcarforum.co.uk/forum/ ... 15&t=42544
MikeT
x 232
Re: Newbie C5 owner
Unread post by MikeT »
Hi Derk and welcome :)
Check the wiring loom between tailgate and body where it flexes, inside the insulated corrugated sleeving. I found wires severed completely and others badly nicked which created all sorts of electrickery including non-opening boot and a posessed rear wiper.
x 1938
Re: Newbie C5 owner
Welcome. Just for future use it would help if you put the year and Mark of your C5.
+1 for the wires in the tailgate loom being broken. It's a Citroen fault (and probably other makes as well) that goes back years. I had a very similar problem on my 2001 Xsara.
derk19601960
x 3
Re: Newbie C5 owner
Thanks everyone for your replies, taken all tips on board, will investigate all once i get it back from garage on Thursday, Thanks again.
wurlycorner
x 271
Re: Newbie C5 owner
Unread post by wurlycorner »
Welcome
And yes to the tailgate loom. Very common in c5 estates (I will get round to mine at some point...)
Iain
CX DTR T2 Safari (silver)
x 6945
Re: Newbie C5 owner
I suspect that the OP has a C5 X7 as he refers to it as a 'Tourer' and +NAV (although confirmation of year would help), so I do not think this is the same issue as the MK I and MK II 'estates' which are a completely different design and don't seem to suffer with the same electrical faults. Neither do they have the tailgate glass opening feature either. :-D
x 6945
Re: Newbie C5 owner
derk19601960 wrote: 18 Mar 2018, 12:55
There are 3 settings, Off, Intermittent and Screen Wash, activated by the end barrel setting. It could be possible that in this very cold weather you the liquid has frozen and the pump has built up pressure, which is causing the washer fluid to periodically release as it starts to thaw and is still under pressure.
See my answer above - but the best thing you can do is put a decent screen wash in that is protected to minus 10 degrees (Halfords do 5 Lt premium stuff and mine never freezes). But if you don't have a premium screen wash, then it likely will freeze in these temperatures and then you can damage the pump by operating it when it cannot expel the water.
If none of the above applies, and the wiper / washer is randomly or constantly operating the screen wash when the system is not frozen then it is likely a fault and your garage should look at it and sort it under warranty as it is a safety device and requirement for your screen washers and wipers to work properly.
derk19601960
x 3
Re: Newbie C5 owner
Hi all,
Latest, Air mass meter replaced, still same, going back this afternoon for them to sort next week, their keeping it until its sorted. Rear wiper is a fault on the stalk, being replaced on monday. Garage 100% committed to getting it sorted, cant fault them at all up to now. Thanks for replies.
