Neighbour's Berlingo
van ordinaire
- (Donor 2017)
- x 400
Re: Neighbour's Berlingo
Shame they didn't offer the HDI in the C15 at the same time but, on the other hand, it does explain why I frequently pass Burlies on the road. Never seen more than 90 on the clock but but well able to mix it in the outside lane, at least on the level bits, as was evidenced only last night on the M5, 3 & 25.
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
Michel
van ordinaire wrote: 26 Feb 2018, 22:01 Shame they didn't offer the HDI in the C15 at the same time but, on the other hand, it does explain why I frequently pass Burlies on the road. Never seen more than 90 on the clock but but well able to mix it in the outside lane, at least on the level bits, as was evidenced only last night on the M5, 3 & 25.
My mum had a C15 based Romahome which I have seen over 90 on once or twice on a test track which was an exact replica of the M60 at night.
van ordinaire
- (Donor 2017)
- x 400
That's pretty impressive, given the extra weight & drag. While I'd reckon on hitting 90 at least once between London & Torbay, in either direction, it's getting too expensive, now MPG's down to low 30's. Oh well, it was fun while it lasted!
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
Michel
van ordinaire wrote: 28 Feb 2018, 18:20 That's pretty impressive, given the extra weight & drag. While I'd reckon on hitting 90 at least once between London & Torbay, in either direction, it's getting too expensive, now MPG's down to low 30's. Oh well, it was fun while it lasted!
I think the extra weight made it sit lower and improved the aero! We also had a 2cv many years ago that was faster 4 up on the motorway pulling a 500wt trailer than it was 1 up unloaded.
van ordinaire
- (Donor 2017)
- x 400
It's an interesting theory, whereas your 2CV observation/experience defeats me completely.
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
OnlineHell Razor5543
- x 3298
Nobody ever said the 2CV was logical. Fun, yes, but not logical.
moizeau
- x 423
I think Michel may have not mentioned the 'downhill' bit.
Pete
MikeT
- x 232
What's the symptoms of out of spec valve clearance?
- x 1240
If they are not closing (to tight) low compression.
- x 8470
Hard to start with clouds of white smoke when stone-cold but starts OK when warm...
It comes of the XUD quirk where the valve clearances are tightest when cold... The colder the tighter...
MikeT
- x 232
Pretty much the same as failed GP's then?
- x 8470
Yes, except that it only happens in very cold weather... Normal mornings it'll be OK...
MikeT
- x 232
Still not given the van any meaningful examination but thought I'd share a quick snapshot of it to see who can spot the mismatch
- x 6950
Well the wheels don't look right and these are not from any Blingo I've seen...
