Fuel cap sensor switch
Bret Sinclair
Unread post by Bret Sinclair »
Got a 1503T2 for my 06 1.6 hdi C5 and totally wrong.
Phoned Citroen and they never heard of it but think it's a plug presence detect harness listed as same place on car from filler neck to top of tank. £125 !!!
Where can I get this from cheaper ?
Bx 16rs
R11 Turbo
C15
Bx 19gti
Ax 14
Ax gt
Peugeot 305 estate
Bx d
Peugeot 406 coupe
C1
+ hundreds of other makes and models.
x 6946
Re: Fuel cap sensor switch
What is it you are asking for? Your post is not very clear.
You say you've got a part and it's wrong - and then you're asking where you can get it from. So are you after a wiring harness from the fuel flap to the tank? A VIN will help too.
Bret Sinclair
Citroen call the part what I said above but I can't find any info.
I need the right part equivalent of the 1503T2 for Vin ending 76748250
Bx 16rs
R11 Turbo
C15
Bx 19gti
Ax 14
Ax gt
Peugeot 305 estate
Bx d
Peugeot 406 coupe
C1
x 6946
Ok, so I think we have some progress...
Here is the diagram for the fuel filler switch (Part No 2). So I'm assuming you need the wiring from that down to the tank...
Filler Unit Switch
Filler Unit Switch
So If I've got this right, you'll need part number 25 on the next diagram - which for your build number (RPO 10732) would be part number 6534 HY - which is 'Plug Presence Detect Harness'. This is currently priced at £103.99 inc. VAT from Citroen.
I hope this helps you with the part now.
Bret Sinclair
Yeah like I said on my first thread and Citroen say it's £103.99 plus vat so near £125.
Bx 16rs
R11 Turbo
C15
Bx 19gti
Ax 14
Ax gt
Peugeot 305 estate
Bx d
Peugeot 406 coupe
C1
Bret Sinclair
But the one on my car has a black magnet on the top of the harness. Pic doesn't look same as mine.
Bx 16rs
R11 Turbo
C15
Bx 19gti
Ax 14
Ax gt
Peugeot 305 estate
Bx d
Peugeot 406 coupe
C1
x 6946
That price is the live price now and includes VAT. It is £86.66 Ex VAT. Just to be clear.
The issue you are going to have is that they changed the harness from RPO 10948 - October 2006, to a new part (6534 NR) - so you'll need to watch out for this changeover if you are going to locate one second hand. I doubt this will be a shelf part for breakers unfortunately.
Bret Sinclair
So no equivalent new part that you know of ?
Don't want to risk 2nd hand, keeping car so want new.
Bx 16rs
R11 Turbo
C15
Bx 19gti
Ax 14
Ax gt
Peugeot 305 estate
Bx d
Peugeot 406 coupe
C1
Bret Sinclair
Seen a pic of the 6534HY And looks same as mine ECC do one for £80.
Thanks for your help, much appreciated 😁
Bx 16rs
R11 Turbo
C15
Bx 19gti
Ax 14
Ax gt
Peugeot 305 estate
Bx d
Peugeot 406 coupe
C1
x 6946
The only other thing I can find is this:
(10) Permanent magnet.
(11) Contact.
The filler cap is fitted with a magnet and when the cap is closed, the magnet is opposite the contact.
Update:
If you look back to the previous diagram, there is another harness (number 26) - which is called the 'Particle Filter Harness'. Although that does not seem to go anywhere near the fuel filler cap, that's the only other thing I can see - that wire is part number 6534 NV and is £27.84 inc VAT. But as I said I'm not sure if this is the one.....
Bandit12
x 12
Unread post by Bandit12 »
Is it the magnet or wiring sensor you need mate? I had similar issue with my old 2.2 hdi. Magnets were fine but sensor failed. There is a link on this site that showed how to make one from.a couple of resistors from maplins. Total cost less than £5. I made one n it worked a treat.
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
raston
New User
Unread post by raston »
Dear Bandit12 where is the link you promised...?
"There is a link on this site that showed how to make one from.a couple of resistors from maplins. Total cost less than £5. I made one n it worked a treat."
x 6946
That post was over 5 years ago....
