Xantia steering column disassembly
x 2009
Unread post by Stickyfinger »
Xantia steering column disassembly, I wish to remove the steering column.
All plugs removed, all loose and all screws that I can see out, switchgear is all loose, but I do not want to force the grey bit
x 1487
Re: Xantia steering column disassembly
Unread post by xantia_v6 »
The grey bit is the steering angle sensor. It it a press fit on the column. Pull harder.
x 2009
Owwwer !
