Michel
Re: Zel's Fleet Blog - Xantia Activa, Saab 900, Lada Riva, Sinclair C5 & New Arrival AC Model 70...
Unread post by Michel »
Zelandeth wrote: 15 Feb 2018, 22:59
I'll certainly happily give any imperial tools that are excess to requirements a home...as I get the feeling this thing will be sticking around.
Would you not be better simply replacing every fastener, nut, bolt and screw with modern, non-rusting metric ones? Not strictly original, but a lot better in the long run I'd expect.
Zelandeth
x 1591
Unread post by Zelandeth »
Most stuff like body fixings and fasteners that are just holding random stuff in place that's exactly what I'm doing. As you say, it's going to save me a lot of hassle in the long run.
The engine is Austrian, so virtually everything associated with that is metric to start with.
The brakes (British) and the transmission (American) are going to persist with some imperial components which aren't readily swappable for metric though. Plus there are some fasteners that I can't just hack off in the first instance, so I still need the right tools to get them off to replace them with something more sensible.
Getting some imperial tools doesn't seem a bad idea anyway as I certainly am not saying we won't wind up with something else old and British in the driveway at some point - there are at least two of us in the house who really fancy a Rover P6 to name one, and of course the Rolls which has been on The List for a long number of years.
Current fleet:
x 8287
Zel, as always, if you are ever in need of any Imperial tools in a hurry I have a comprehensive collection from the days of me spannering much British tin...
Zelandeth
x 1591
May well take you up on that Jim, just need to figure out what sizes I really need.
In the long run I do need to buy a set though! Just been a bit of an expensive month so trying to keep spending under control!
Current fleet:
x 1480
Have you seen 'Hub Nut's' series on Youtube.....?
Zelandeth
x 1591
RichardW wrote: 17 Feb 2018, 15:31 Have you seen 'Hub Nut's' series on Youtube.....?
Yes...His posts on another forum are entirely to blame for me discovering and ending up with one of these things. I'd never heard of them until that gent got his pair.
Had a dig around through my old toolbox of junk today and located a handful of imperial spanners. Also dumped about 2/3rds of a toolbox of cheaper and nastier copies of tools that I've since replaced with better versions...so this toolbox will officially now be the imperial toolbox so I don't wind up mixing everything up and getting hopelessly confused.
Today I had two tasks in mind. Firstly was to get the indicator stalk assembly off the spare handlebars. This involved getting the drill out to drill out the one screw that someone had rounded the head off of some time in the distant past. Then allowing me to get at it to unscrew the remains.
This pair of adjustable grips is a standard piece of the Saab 900 toolkit, and is one of the most used tools in my toolbox.
I am however going to need to do some repairs to this before I can fit it, as there are several broken wires, which are going to be at best fiddly to sort...Waiting to find out what car the stalk assembly is shared with, as it a replacement is readily and cheaply available I may just opt for that.
Next task was to get the rigid brake lines off. Having the correct sized spanners made this a much more approachable task. This is one of those areas where the quality of fasteners etc that have generally been used on this thing really shows. Every single union came undone without any drama, any stripped heads or anything. The only slight casualty was the bracket the rear T joint body is attached to the chassis by is now slightly bent.
Here's what came off...
I did cut the main front-rear section in half just to make the job simpler, as I had perfect access to do that with the floor currently out.
...The final bit of the front-rear section is actually hanging on the master cylinder, I forgot to pick it back up for the photo.
The only bits I've left be are the first pipe from the master cylinder to the first union, and the pipe that goes from the rear flexi to the rear wheel cylinders, as they look fine. The one to the front flexi would have been fine too if some idiot (that would be me) hadn't nicked it with the grinder when cutting the master cylinder bolts off. Oops.
Will be having a closer look at the rear wheel sections before I make a final choice on whether they come off too though as I'm not taking chances with this - especially as I know I've said this before, but it bears repeating...You don't take chances with a single circuit braking system as they don't take prisoners if things go wrong.
Current fleet:
Zelandeth
x 1591
Absolutely nothing to show for today practically speaking.
I have however started to put together pages for my website for both the Activa and the AC. Not online yet, but with a bit of luck might get them uploaded tomorrow. ...via a USB stick as the FTP server is still playing up and I've not managed to summon the botheredness to investigate why yet. Won't likely be anything there you've not seen here, but I really need to get back in the habit of updating it again.
Main task car-wise tomorrow will be checking the final brake lines and make a decision on whether to change them, then look at getting in the flare nuts etc needed to make the new lines up.
If time (and weather) permit I *really* need to get the Activa a wash too.
Current fleet:
x 8287
Zel, don't worry about non-productive days - we all have them... Main thing is not to beat yourself up about it ;)
And that's from one who has plenty of them with utterly no warning they're approaching :twisted: I'm a specialist on them...
Anyway, you did! I call doing website updates very productive and I'm looking forward to seeing them :)
Zelandeth
x 1591
Think probably the main website update I need to do at some point is to do a proper fresh OS reinstall on the server to hopefully banish some of the glitches once and for all. I have a sneaking suspicion that a lot of the current issues are down to having copied over the whole home folder when I set the current machine up rather than just the website folder - because I'm stupid and was in a rush. Given that I jumped something like five versions and to a different Linux distro at the same time, that was a recipe for "interesting" things happening.
...Or have another bash at getting Apache to behave on the Raspberry Pi that runs our NAS, allowing me to centralise everything on the same machine. Had an issue there with file permissions that defied all attempts to resolve it last time I tried. It worked fine if everything was running off the SD card, but gave "access denied" errors as soon as you moved the www directory to any other media - irrespective of having granted what by all accounts are the right permissions.
I chased that around for a couple of hours a while ago (when the hard drive died in the actual server), but gave up in the end and just threw a random low spec laptop at the job in the end. I'd ideally like to get that running on the Pi at some point though... that's one of the things I bought it for.
Current fleet:
x 8287
Zel, can I recommend CentOS 7 for your reinstall? It's what I use with great success and reliability and can give you any assistance you might need to fine-tune it...
In fact, a lot of my configuration for the web server, ssh/sftp and so on will go straight across...
I'd not recommend FTP any more... Go for SFTP using a tool such as Filezilla or WinSCP if you do it from Windows and you'll find it a lot better and easier to configure...
Zelandeth
x 1591
Pretty sure I've got CentOS on disc somewhere... obviously download the most recent version.
FTP is something I've only been using locally (the firewall doesn't allow external access to it), though there's no good reason not to upgrade really if I'm setting things up from scratch...the reason I'm still using the old setup is purely down to how long ago I originally set things up!
Today I made a trip back over to the house the AC came from to pick up the handful of bits we forgot and the door window glass. We left that before as we couldn't see any safe way to transport it along with everything else when we brought the vehicle back.
So now I've got all the clips etc to reassemble the remaining brake drum. I've also got a fuel tank (not technically the correct one, but we'll make it work), and most importantly I've got this.
Won't have a chance to do much tomorrow as I'll be playing taxi for most of the day sadly. May well try to get the last drum built up in the evening at least if I get a bit of time.
Current fleet:
van ordinaire
(Donor 2017)
x 402
What HAVE you got in the washer reservoir?
I'll sort out those spanners over the next couple of weekends (not that there's that many - but nor are there available hours) & let you know what to expect.
f-w-i-w, those brake unions might well be Whit. Most British makes seemed to go from that to metric (although my 2.5 PI had Whit. AND imperial randomly throughout the brake system - just to confuse).
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
Zelandeth
x 1591
Luckily I've got spanners which are a good fit on all the brake components.
As predicted I only had a few brief moments available today to get anything done.
First up was hitting things with hammers. Have successfully managed to free off the parking brake mechanism. This is good. Can confirm it's working nicely on the wheel with shoes in as well. Planning to get that reassembled tomorrow.
This evening I got the indicator stalk assembly cleaned up and reattached the couple of wires that had come adrift. It's not pretty, but should do the job. Have also attached screw terminals to all of the wires ready to be reunited with the rest of the loom.
The fuel tank I've got is definitely full of gunk... cleaning that will be "fun" I'm sure.
Will have a dig around tomorrow as well to see if I can track down some suitable materials from which to fabricate a battery tray, as it would be nice to get that back in the right place again.
Current fleet:
Zelandeth
x 1591
Okay, first task for today was to reassemble the one remaining wheel as I now had the full compliment of clips etc.
Jack it up, wheel off, drum off...
...This one hasn't been dismantled.
Cue much swearing as I'd been sitting around waiting for a week to get bits that it turned out I didn't need. Have also confirmed that the handbrake is working on this one too. It will happily hold the car sufficiently well that I can't push it, the cable is still binding quite a bit though - will give it a thorough greasing as soon as my grease gun appears (there's a grease nipple on the cable at the mid-point).
Fine...Stuffed that wheel back on (with a full compliment of four wheel nuts rather than the two it came with) and turned my attention to the rest of the brakes. I knew I had quite a few bits of NOS braking kit floating around, so decided to do a bit of a stock take.
First up was a new full front-rear section, still in its massive cardboard sleeve. That was immediately dug out and I set about installing it. I was definitely right to do this before putting the floor in, as threading it through the cutouts in the chassis would have been quite fiddly from underneath.
I needed a bit more height to get at the union between the two sections at the front (which is helpfully under the bit where the floor and body overlap, so there's no access from above!)...however was able to do something you just can't do with normal cars.
Now this doesn't look too unusual...what's unusual is that I was able to simply pick up the front wheel by hand and plonk it down on that wheel rim. I should have used a couple really, but one actually gave me ample space to work. Rear wheels were of course chocked so it couldn't fall off.
You can't really see much difference here - but there's now a nice new brake hydraulic line running from the front distribution T right back to the identical one which splits the feed to the rear wheels just ahead of the rear axle.
Even successfully managed to get it back into all the original clips. I'll probably cut a bit of rubber pipe and put it in where the pipe goes past the upright and vanishes under the body - I don't like the idea of the pipe rubbing on that unfinished metal edge.
I've also swapped out the front flexi for a NOS one. The rubber on the one that was there actually looked fine externally (no visible perishing, and it was definitely still flexible, not having turned to plastic like a lot do), but the ferrules were quite badly rusted. The new one aside from being a bit dusty looks and feels like it just came off the production line.
There are a few other bits of rigid line that I just need to figure out the correct location of. Think I should have everything I need save for maybe the line from the front union to the flexi for the front and the offside rear...So that's definitely saved me some work!
Current fleet:
x 8287
More great progress Zel :)
