Picasso throttle cable
Ttwlr
Unread post by Ttwlr »
Where is the location of throttle cable on 2005 2.0 HDI ? Peddle gone slack and not getting full throttle
x 6963
Re: Picasso throttle cable
It depends on your model - some are fly by wire - with an electric potentiometer incorporated into the accelerator pedal or you may have the version with a cable. To check which you have, send a private message with your VIN.
Ttwlr
Message sent
Ttwlr
Need to adjust it as can get much speed pulling out on roundabouts etc, got about 2” travel to floor
x 6963
Ok, I've had your PM with the VIN - and it is the cable version.
The replacement part for cars over 3 years old is: E074600 - and is £30.85 from Citroen if you need to replace it.
Having said that, they also made a modification to this with a kit to replace it with an electronic pedal. It requires fitting the brackets, cable routing and some electrical wiring modifications and removal of the old sensors etc.
But the cable would still seem to be available.
Ttwlr
Thank you Marc, is it possible to adjust to cable for now ?
And are they easy to replay ?
x 6963
You need to be careful because if you take too much slack out it will affect the running as the idle settings are different when hot / cold.
There's a little more on it here:
https://www.frenchcarforum.co.uk/forum/ ... ttle+cable
Ttwlr
I only want to adjust a bit, trying to find pictures so I know what to look for, or YouTube vid
Ttwlr
Has anyone got photo or tell me where to find the cable in engine bay please,
x 6963
This picture below is related to doing the modification I mentioned - but it would indicate that the control cable is routed in / under / along the scuttle area: (a) being the location of the control cable.
Ttwlr
Thank you Marc, as my throttle peddle is floppy would this be the cause for sure, I can lift it up and i when let go it just drops down, still drives ok just slow pulling out and in 2nd gear I’m flat out trying to get to 30mph lol
x 6963
It’s a very good bet the cable has become too loose. The pedal should not be that low down.
If you can get someone else to operate the pedal it might help you locate it easier and find the adjustment thread. Do a little at a time until it returns to normal but don’t over adjust it.
Ttwlr
This is it, the black long thing just goes through the hole, is this bad ? Or do adjust another way
Ttwlr
Would thick wire tie work
Ttwlr
Done thIs and seems to work
What’s ment to be there?
