Bosch fuel pump insitu De-armouring?
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
Okay guys, have always thought the veg burner has gone Well for a 90 horse from the factory wagon, had pretty much convinced myself it had been tweaked, however after a fair bit of searching the net, nosing many guides on how to up fuelling, boost etc. Staring at the pump i couldn't work out why mine wad different, more Internet searching, thus time 406 versions i found one that looked like mine with the armour on, so that explained why i couldn't see the relevant bits,
All the ones de-armoured seem to have been done on a bench, so i kinda gave up on the thought of having a go, But! Its been niggling about in the back of my head, Is it possible to do in situ?? I think one of jims guides suggested not but was a few years ago.
What is niggling is this, would it be possible to use s dremel type tool to cut away the area around the fuel screw without having to remove the pump from the car?
Or is it just worth leaving it alone and living with it how it is??
Thank you in advance for your time to read this waffle!
Timmo.
'58 C2 Code
'58 partner teepee outdoor
MikeT
x 232
Re: Bosch fuel pump insitu De-armouring?
Unread post by MikeT »
As you probably know Timmo, the armour protects the immobiliser circuit. Unfortunately, as you've discovered, makes the max fuel screw inaccessible too!
The good news for you is, that's not the only adjustable part affecting performance. The other main part of the pump you can access is the LDA which works off manifold pressure and has a few adjustable parts to control pre-boost and on-boost fuelling and not forgetting the turbo wastegate adjustment down the back of the engine.
I blogged my dismantling of a pump once which covers what bits do what in fair detail if it helps.
ekjdm14
x 262
Unread post by ekjdm14 »
Not sure if it's any help (probably not!) but I did cut the armour off a Lucas pump in-situ one time. I have a feeling the Bosch may be tougher to reach but it's not all that bad to remove the pump if you really wanted a go (you can leave the timing belt in place by using the locking holes to hold the pulley, just leaving the awkward lower fixing that can be got with a half-moon spanner/heated and bent 13mm combi if you're cheap like me!).
To be honest though I think you'll find most of the gains, if any left to be had, by adjusting the LDA to fuel a bit more aggressively as the boost builds and upping the boost a tad. I feel once you get into needing to up the max fuel you're close to the limits of what the stock turbo/intercooler setup can put up with for any length of time.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
MikeT
x 232
Oh P.S. My blog also details how I removed the armour though I had the luxury of doing so on the bench so it may not be wholly applicable to in-situ removal.
Having said that, I know it can be defeated in-situ but is not a job I would entertain if not absolutely necessary. While the max fuel screw is a simple adjustment, it does affect the entire fuelling range and would still likely require tweaking the other settings available, especially the idles (both cold and hot) and the max revs setting to avoid potential engine runaway and destruction.
x 8403
MikeT wrote: 14 Feb 2018, 12:00 Having said that, I know it can be defeated in-situ but is not a job I would entertain if not absolutely necessary.
Very much agreed... I've seen an engine wrecked whereby a bit of armour lept off during rather 'enthusiastic' removal and ended up in the inlet tract and then into a combustion chamber...
The mess was unbelievable... I may still have some pictures of the carnage...
ekjdm14
x 262
Oh dear, yes that would be interesting to see if you don't mind digging out the pics Jim... If only to feel slightly better about having had to do the major surgery on White lol.
in that case I can only advise against removal in-situ. The ZX application with top-mounted intercooler didn't require the intake pipework to be disturbed.
Timmo
(Donor 2022)
x 168
Ooooh those pictures sound interesting Jim!
Im not dead set on doing it, but just something that has been niggling away,a little more so when i lost 20mph up a local hill (the only 3 lane section in the county!) with just me and the bike in the back! :-O i have read a lot about how to tweak them, first fitting a boost guage to make sure you dont go over 18psi. The wastegate tweaks. Boost compensator, amd the fueling screw, the stumbling block is the armouring,
My thought on the dremel was purely down to many rears back i used one to cut through the downpipe where it enters the resonator box on the 16v bx, I'd caught it on the edge of inlaws driveway, with a flexi hose and a few cutting discs it did a surprisingly good job! Hence my thinking if it would be possible to cut around the area with the fuelling screw, kind of taking the corner off the Armour?
'58 C2 Code
x 8403
Pictures of the damage from a small piece of armour 'shrapnel'
This was an otherwise very sound 1.9TD...
I saw it with my own eyes...
If you do de-armour in-situ then be sure to plug up all orifices very securely!
Timmo
(Donor 2022)
x 168
Oooooooh thats quite nasty! Stsrk reminder that it doesn't take much to get in thst causes a Lot of trouble!
'58 C2 Code
KennyW
x 165
Unread post by KennyW »
Timmo,
You can dearmour a bosch pump insitu but take necessary precautions to prevent any accidents.
I used dremel to remove the snap off bolts by cutting a small groove into the head and then they came out with a screwdriver. Some may need a bit of gentle persuasion.
This was at the same time MikeT was doing his refurb of a pump circa 2010.
MikeT put a link on DavieMc's post recently about the same thing.
Kenny
C3 1.4 petrol (SWMBO)
daviemck2006
x 485
Unread post by daviemck2006 »
And mine is not even started yet. The weather is just too cold and wild to do anything outside here.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 8403
daviemck2006 wrote: 14 Feb 2018, 23:04 And mine is not even started yet. The weather is just too cold and wild to do anything outside here.
It's not much better down this way at the moment Davie :( It's stopped all outdoor work for me...
Michel
Unread post by Michel »
CitroJim wrote: 15 Feb 2018, 06:07
Ah, you're all soft! Tis but a summer's shower for us from East Lancashire..
ekjdm14
x 262
Wow that was some nastiness Jim! Did look from the photo though that the bore had survived relatively unscathed, did they end up replacing a piston/rod & head or was the block scrap do you know?
It's lovely and sunny in Congleton today, just about to ring and see if there's anyone "home" at the scrap yard so I can grab my airbag goodies. Nice to see a bit of sunshine for a change.
x 8403
The engine was scrapped Dan...
It's been utterly gorgeous here today.. Robyn and I made the most of it by going for a long walk into town for a coffee and a trawl of the charity shops looking for books and vinyl :)
The thing that stops me working well when the mercury drops is not the cold as such - I have no great problem with that - but the bloody Reynauld's that renders my fingers useless :evil:
