Am i in trouble here faulty diagnostic port
Webo83
Is this a sign of a bad ecu my diagnostic port doesn't work I've checked fuse that's OK which I knew because it actually turns the machine on but will not connect it says unable to link with vehicle check ignition etc I've also tried unplugging various sensors which I saw as a poss problem on a YouTube vid but to no avail but I do have the traction control light on (car with the two lines) and a handbreak light coming on once I start to drive any ideas welcome but I think this c2 is more trouble than its worth only had it 10 days and I'm ;£400 deep into it for parts and labour the original idea was a cheap car to run lol
Lighty
- x 34
Re: Am i in trouble here faulty diagnostic port
Your post doesn't make the most sense if you read it back.
However, if you connect to the obd & it powers the Diagbox machine, then the plug is usually ok .
What tool are you using ?
I would auggest trying a completely different one.
If you are using a simple scanner, it won't connect with the abs anyway.
Have you checked the brake fluid level ?
It needs to be very full to keep the red handbrake warning lamp off.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Webo83
Yes sorry if it sounds a bit muddled but it powers up but says unable to link with car the tester works on our 2010 astra so I know this works I've looked into it and found it could be a earth problem in pin 3 or 5 I think it was because we are getting power but no link
