C4 Picasso 1.8 (07) wont idle,EML lit/brake warnings and no brake servo
elcustardo
x 9
Unread post by elcustardo »
Im probably going to dump the car to the mechanics as Im sick with a chest infection/lurgy.
However thought I may pick the brains of those in the know.
Car was running fine and as I turned into a multi story the EML came on with emission/brake warnings.
Power was way down with a lumpy throaty engine.
Strangely lost servo assistance on the brakes? Dont know if thats a clue to something as not something I had with cars in limp home mode before.
Also getting backfires in the engine bay area.
Engine will idle roughly but not rev much past 1.5K revs.
Got the car recovered. Mechanic checked fault codes.
apparently 'many' were present.
One I saw was P1158,Mechanic mentioned throttle position sensor too.
Car hasn't missed a beat. Only thing I could say is maybe the idle has been a little rough of late.
Allowed the car to cool down and it no longer idles. Starts revs to around 1K and then dies off. Accelerator makes no difference to revs.
Tried disconnecting/reconnecting battery.
Car gets a good mix of town driving and 20 miles daily on motorway runs. I have an OBD scanner arriving today so will recheck codes.
Any advice or insights appreciated.
x 6963
Re: C4 Picasso 1.8 (07) wont idle,EML lit/brake warnings and no brake servo
Welcome to the Forum.
Your generic scanner probably won't be able to provide much info unfortunately except provide basic fault codes - but that is better than nothing.
Let us know what fault codes you have, along with your VIN or Reg - and we'll see if we can provide more details of the faults.
elcustardo
x 9
Well the votes are in.
Reg is REZ 1409
Got the code references from anther site. Hope they are correct
P0123 Throttle Position Sensor/Switch A Circuit High Input
P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich
P1153 Bank 2 Fuel Control Shifted Lean
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P1161 Throttle Position Control Coherence
Hope this gives some clues?
EDIT: While I was out I tried starting the car full throttle,seemed to stay running a teeny bit longer,mashing the pedal again possibly a teeny bit longer but we are talking near imeasurable difference
elcustardo
x 9
Sorry,realised after I posted. Edited the reg in. REZ 1409
x 1470
Sounds to me like the throttle body has fallen apart, leading to the loss of manifold vac, and control of the mixture.
elcustardo
x 9
So new throttle body being the most likely candidate?
I had wondered if the loss of brake servo was a red flag to something.
Quick look on Google makes it look a fairly easy bolt on part? at around the £150 online ,Citroen dealer wants £210 for it
x 6963
So this one is the C4 Pcasso 1.8 i 16v 125 Manual gearbox - with Magneti Marelli injection.
It's also possible that the Accelerator sensor could be playing up:
Role of the sensor:
  • To register the driver demand (acceleration, decelaration)
  • To deliver the information to the injection ECU
The role of the injection ECU in terms of the information received:
  • To determine the opening of the motorised butterfly
  • To determine the injection time
  • To determine the ignition advance
elcustardo
x 9
Yeah I saw that,one on Ebay just now. However the lack of servo on the brakes leans me towards the Throttle over pedal?
I'll be honest until I started reading up I didnt realise it was fly by wire.
Im not into the spanners like I used to be.
elcustardo
x 9
Right folks. Removed the throttle body. I had hoped to find a hole in the pipework or an obvious issue but no.
Looking online this seems about the best price
http://www.mister-auto.co.uk/en/throttl ... -001Z.html
£144.81 delivered with 10% discount. I would like it quicker but the dealer is an extra £65 and I may still have to pay for other parts if it doesnt work!
Any views on the store or better/cheaper options?
Thanks for the help so far.
elcustardo
x 9
Okay so took a gamble and phoned Eurocarparts.
There were £175. Asked if they would match the online price and they have.
Will be in stock this afternoon!
So I will update if she comes back to life.
ekjdm14
x 251
Unread post by ekjdm14 »
Good luck with it and hope the new TB solves the issue, I have to admit the first thing that sprang to my mind on seeing this post just now was perhaps the brake servo pipe had split or the servo itself had ruptured... I suppose a quick vacuum check if you have a vac pump would help to put this one to bed before fitting the TB making it non-returnable...
(actually, if you're very careful not to mark it during trial fitting it may still be returnable if not the solution... Normally not my way of "playing" but with ECP I have no qualms)
'96 ZX SX 1.9TD, White, 88k
'98 Ford Fiesta 1.3i 72k
elcustardo
x 9
She lives! After a hesitant cough at start (where my heart & wallet sank) she is back like a trooper.
I cant really tell if she is running smoother/better but it certainly feels a wee bit better.
I have temporary(I hope!) deafness in one ear so my senses are a bit off.
Many thanks for all the help :)
ekjdm14
x 251
If the fuel trims and such are all out of whack then perhaps it'll improve further after a few ignition on/off cycles and some driving since it'll have to re-learn the values with a working TB as opposed to the ones it "learnt" in correcting for the failure. Hope that's the end of the issues anyway.
x 6963
Excellent result - thanks for updating us.
