I have recently gotten a Citroen c5 2.0i 2006. I was checking the hydraulic fluid level, the fluid didn't look good. It has no colour to it. Looks a little grey maybe, and very thick and dirty.
When I open the LDS cap it smells like old power steering fluid. A little bit burning smell that comes when a power steering fluid is old and needs to be replaced.
I have no experience with changing LDS fluid on a Citroen, so what's the easiest way to change the fluid?
Citroen C5 - Changing LDS fluid
EDC5
- x 130
Re: Citroen C5 - Changing LDS fluid
I'd wait for a more experienced opinion but what I did was open the bleed nipple on the front suspension strut and allow it to drain down a hose into a container. And again for the rear bleed nipple located by the rear centre spheres. This got most of it out, then top it up in the normal way.
The other method I considered was to use a large pipette to extract as much fluid as I can from the fluid tank with the suspension on low however this wouldn't replace it all and in your situation I think you could do with a full change.
Cupi34
Correction, I cannot actually see the fluid when the car is set to low position. The only thing I saw was a hard round plastic cover (I guess) inside the tank. Should this be there by the way?
So I don't actually know what the fluid looks like. However, when I open the LDS cap it smells like old power steering fluid when the engine is hot. The smell is not too strong, but it is there.
So is this type of smell normal from LDS fluid?
EDC5
- x 130
The LDS should just about be visible when on low at the bottom of the 'basket' you describe in the filler of the tank.
Here is some LDS:
I'm not au fait with the smell of power steering fluid so I can't help on that front but if in doubt then replacing the fluid will do no harm.
Here is some LDS:
- x 6947
Here's the procedure for a MK II Drain and Refill:
Remove:
Uncouple the hose ( 2) from the LDS fluid reservoir.
Drain the LDS fluid reservoir.
Refilling
Connect the hose ( 2).
Refit:
Open the plug ( 3).
Add LDS fluid until the level is between the minimum mark "b" and the maximum mark "a".
Bleeding
- Start the engine.
- Place the suspension height control in the "LOW" position.
- Stop the engine.
- Raise the vehicle and support on axle stands, wheels free.
Remove:
- The front right wheel
- The front right mud guard
Refilling
Refit:
- A new clamping collar ( 1)
Open the plug ( 3).
Bleeding
- Apply a pressure of 0,5 bar in the LDS fluid reservoir (using a FACOM 920 tool).
- Start the engine.
- Wait for the vehicle height to stabilise.
- Place the suspension height control in the "HIGH" position.
- Turn the steering from lock to lock in each direction.
- Stop the engine.
- Check the LDS fluid level.
Cupi34
Thanks,
Should the car be put on axle stands only on the right side? (Only the right side which is lifted up)
Why do I need a new clamping collar (1)? (Can I not use the old one)
- x 3297
While I cannot offer advise over the collar I do know that Paul (citroenxm) was able to BLOW hard enough into the LDS reservoir for it to achieve the required pressure. However, I have the bits to make an LDS cap with a tyre valve so I can, with a couple of strokes of a bike pump, pressurise the system without getting my mouth dirty.
- x 5675
What about the fluid n the power steering circuit?
- x 6947
Fed from the same reservoir Steve as you know, but you’ll never get it all out. Maybe slightly more will be released back into the tank using a Lexia to depressurise the system. But sufficient to replace most of the fluid using the manual method. The system is self bleeding for the most part, but the steeeing specific part is covered in the bleeding section.
- x 5675
As I suspected.
I'm sure that disconnecting the pipes at the rack is just asking for trouble.
The hose No2 in the picture has a join at the bottom which is easier to separate than the one (No 1) at the top, the hose can then be dangled in a bowl on the floor to save getting drowned in oil.
You would only need to remove No1 if you were intending to remove the reservoir.
Cupi34
Does anyone know how much LDS oil is needed to fill up the tank after draining?
411514
- (Donor 2017)
- x 39
No, I don't. I would guess however at about 2 litres. In the UK at least LDS can be gotten relatively cheaply, so if I were you I would buy 3 litres and I should imagine that will be plenty.Cupi34 wrote: 18 Jan 2018, 15:54 Does anyone know how much LDS oil is needed to fill up the tank after draining?
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
This do?
- x 5675
When all mine leaked out I put 4L in and it wasn't enough.
