Confused windscreen washer; front not working. [C5 Mk1)
Spurious
Re: Confused windscreen washer; front not working. [C5 Mk1)
Post by Spurious »
For the sake of a tenner, I've ordered one. I'll pull it apart over the weekend, hopefully that solves it! Be the last of the gremlins with the C5 at least for a while.
Phase 2 Xantia HDi
Sold
Phase 1 Xantia Activia
Sold :(
Phase 2 Citroen C5
Sold
And a current semi-working MK1 C5 Hdi 110.
x 6953
Post by GiveMeABreak »
£10 for a genuine one isn't bad considering what they charge for silly bits of plastic trim - no sense in getting a pattern part if you can get on OEM one for the same price. Carefully remove the wheel arch lining and easy enough to get to.
Spurious
Post by Spurious »
Yep, I ordered the OEM one you linked there Marc, good find. :)
Phase 2 Xantia HDi
Sold
Sold :(
Phase 2 Citroen C5
Sold
Harlequin
x 24
Post by Harlequin »
i`ll put money on it being the comms unit - I had exactly the same probvlem
x 6953
I was thinking that Simon, but for a £10 it's got to be worth a pop first. :)
@Spurious - Have you been having any other issues specifically with indicators not cancelling or random switching on / off of headlights? Those can all be attributed to a dodgy comms unit - but if not fingers crossed the pump will sort it.
wurlycorner
x 271
Post by wurlycorner »
Spurious - there are some pics of the washer pump / pipe arrangements in my C5 profile thread, if you want to see what's involved. (Link to that in my signature strip)
Iain
CX DTR T2 Safari (silver)
Spurious
Post by Spurious »
I've had a look at that there WurlyCorner.
By looking at your post I think I could get at the pump by just removing the wheel liner? I'm not taking the bottle out, just gonna swap out the motor and inspect the pipework.
GiveMeABreak wrote: 09 Jan 2018, 22:31 I was thinking that Simon, but for a £10 it's got to be worth a pop first. :)
Sorry, I didn't get a chance to reply, I've been on long shifts during the week, has me knackered.
Nope, it's been behaving itself more or less since I got it. Auto headlights do what they should. Indicators do what they should. There's a sticky hazard light button but that's on the list.
Phase 2 Xantia HDi
Sold
Sold :(
Phase 2 Citroen C5
Sold
x 6953
That's a good sign then, those are some of the issues that can indicate the comms unit failure - my MK I even went so far as loosing all the instrumentation / interior lighting on the motorway - everything electrical on the dash - heater A/C audio - all went dead, Everything fired up on startup, but the comms unit was replaced and was at fault - probably one of the earlier ones, but unnerving to say the least!
Spurious
Post by Spurious »
Result, I can see out my windscreen now.
It was the pump after all. Not fancying a bumper off job in the sleet and snow, I just loosened the bumper mounting screws and the wheel arch liner. Managed to get enough clearance to squeeze my hand in and pull/twist the pump off it's rubber bung. 15 minute job in total, quite happy with that. Thanks for all the help folks. C5 is mostly clear of little niggles 8-)
Phase 2 Xantia HDi
Sold
Sold :(
Phase 2 Citroen C5
Sold
x 6953
Excellent, a relatively easy, cheap and pain-free fix. :-D
Spurious
Post by Spurious »
Thankfully it was a quick job as it was baltic out. Always jealous of folk with garages in this weather.
Phase 2 Xantia HDi
Sold
Sold :(
Phase 2 Citroen C5
Sold
