Can anyone recommend a good trolley Jack and axial stands
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: Can anyone recommend a good trolley Jack and axial stands
Bick wrote: 30 Dec 2017, 09:21 Its fun getting mine under my mates 350z and surprisingly under the front of my Berlingo?!
I have a similar problem with my 405, there's not enough clerance between the subframe and the deck to get the trolley beneath.
I've found the best way around this is to use a small bottle jack with a length of wood (mine's about a ft long) under the front cross-member (assuming there is a metal cross-member on these, don't do it if its all plastic) just to raise the suspension. Having done so there's then clearance to get the Trolley under the Subframe.
Obviously, don't attempt to lift the car beyond the suspension travel like this.
Puxa
x 1746
It was for that reason that I bought a low-height trolley jack - plenty of them about, same price as standard ones. Compact enough to put in the boot for long journeys away from home.
x 2938
You could of course just drive it up on wooden blocks first to make room for the jack to go under. :)
x 5690
I'm still using my dad's trolley jack, must be 40 years old now.
I did have a set of axle stands that were great - raise suspension, pop them under, drop suspension and the wheel magically lifts off the ground for changing.
I believe they were added to my ex-son in law's collection.
Bought some replacements (Halfords) and they are half an inch too tall to fit under the raised car :(
x 8470
One of my Halfords jacks must be getting on for 40 too Steve...
Still does the job but does leak a little oil in its old age!
crapday69
(Donor 2017)
x 59
Unread post by crapday69 »
I'm lucky as my son is an apprentice light vehicle technition (Arnold Clark Mazda), he gets a good discount at halfords. aamof I just saved £29 on a new battery :).
50% off Car bulbs
40% off Spark plugs
30% off Windscreen wipers
30% off Mirror glass
30% off Air, fuel, oil, and cabin filters
30% off Fixings, fuses and electrical accessories
25% off Engine Oils
25% off Additives, antifreeze, de-icer, screen wash
20% off Brake pads
20% off Hand tools
20% off Battery chargers and accessories
20% off Single Sockets
20% off Lifting & Metal Storage
20% off Car batteries
20% off Motorcycling products
15% off Car Cleaning products (excludes Karcher)
15% off Spray paints & body repair
10% off all car accessories including car mats, wheel trims, tints, alloy wheels and air fresheners
So if you know anyone or if you are a mechanic and dont have a trade card with Halfords, then get a move on.
Gary.
KennyW
x 165
Unread post by KennyW »
SGS engineering are currently doing a jack for about £25. The only drawback is the max height is 385mm.
Kenny
C3 1.4 petrol (SWMBO)
