Xantia not starting
daviemck2006
x 485
Re: Xantia not starting
Unread post by daviemck2006 »
Well after tightening the clamps she had the phut to start bigpug, which was well down. At the end of the jump leads was getting 13.9 going into big pug. I gave her a cup of tea time before starting it.
There was a quick shower here a wee while ago, was that your tea Jim?
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 8395
daviemck2006 wrote: 19 Dec 2017, 16:36 There was a quick shower here a wee while ago, was that your tea Jim?
No, couldn't have been as the tea was still in the kettle at the time - good job too :lol:
daviemck2006
x 485
So now, as I have done a few jobs to Gabby now, and Jim always says he has no problem with his nuts second time around, we can surmise that he only ever goes hand tight on his nuts :dom: :dom:
Peugeot boxer 2016
In the family
x 1746
Good news about Gabby starting, and having enough va-va-voom to get the big girl going too.
Always good to get a grip... :?
x 1996
Unread post by Stickyfinger »
I have this memory problem, which ones have I done ?, forgotten ?, not seen ?....I have resorted to TIPPEX now, I mark each bolt when, and only when, correctly tightened. On engine-2-part bolts, it has the added advantage (if you use a large "dollop") that you can see if a bolt has loosened and is equally useful at night if ever you need to find bolts in the darkness of an engine bay!
x 3296
Well, based on Michels oil filter problem, I know which way I would prefer things to 'fail'! (although I would prefer filters to remain reasonably securely in place). I recall having to take Bluebird to the local scrap yard to get a locking wheel bolt removed. It took them 45 minutes (and cost me £20) to break it loose (it also broke 2 correct 'keys', and eventually had a socket hammered onto it). She now has standard wheel bolts all round!
daviemck2006
x 485
The lockers on my daughters audi were impossible for me to shift. It took a garage 2 hours to get all 4 off. I hate lockers with a passion, and usuallyone of the first things I do with any car I buy is consign them to the bin
Peugeot boxer 2016
In the family
x 1746
Not helped by tyre-fitters love of the rattle-gun, and aversion to a torque wrench. Invariably over-tightened.
Michel
Unread post by Michel »
white exec wrote: 20 Dec 2017, 07:37 Not helped by tyre-fitters love of the rattle-gun, and aversion to a torque wrench. Invariably over-tightened.
Precisely why I always take my cars to the same place for tyres and have for 13 years. They do it properly, torque wheels properly, have no problem balancing centreless wheels. Great place. Small family run place in Binfield.
x 8395
Michel wrote: 20 Dec 2017, 09:08
I do the same but often I just take wheels as they're only at the other end of my road... They like that as it saves them a bit of work...
x 695
Unread post by Mandrake »
Was there any gap between the two halves of the battery clamps when they were loose ?
The usual reason for battery clamps coming loose unexpectedly is that the clamps are sitting too high on the tapered post and thus the two halves touch each other before the clamp is fully tight on the posts. Tightening the bolt just squeezes the two halves together tighter but doesn't squeeze any tighter on the post. So even though the bolt is tight and everything looks good if you give the terminal a good twist you'll find it lets go fairly easily...
To avoid this, if there isn't a gap of at least a few mm I always slacken the bolt off a few turns, use a flat blade screwdriver to spread the two halves and make sure it pushes further down the taper of the post then tightens up nicely with a gap between the two halves of the clamp. And then afterwards I try to rotate the clamp by hand to make sure it actually is biting on the post properly.
Sorry if I'm trying to teach you to suck eggs, but a lot of people don't seem to be aware of this potential pitfall of tapered battery posts... :)
x 8395
I think in this case it was me being very careful in tightening them Simon. I'm always very conscious of how delicate Xantia battery clamps are and act accordingly...
However, having said that it was a good six or seven months before Davie had her that I last had the battery out...
daviemck2006
x 485
There was a gap between the clamps as there should be, the earth had slackened and it just lifted off. The positive was tighter but still came off with a twist, si its connection could have been fine. She did a few miles of stop start deliveries last night with no problem. And at this time of year its all in the dark so heavy loads on the battery, but had 3 times to neighbouring villages which are 5 to 7 miles distant, always better getting one or two of them to give her a bit of a run.
Peugeot boxer 2016
In the family
Michel
Mandrake wrote: 20 Dec 2017, 09:47 Was there any gap between the two halves of the battery clamps when they were loose ?
Yes, that is the usual reason.
The other reason on Citroens that have been bought from North Bucks is that Jim's "tightened" them :-P
x 8395
Michel wrote: 20 Dec 2017, 10:51 The other reason on Citroens that have been bought from North Bucks is that Jim's "tightened" them :-P
:rofl2: Another keyboard was at risk again then ;)
From coffee this time!
