Xantia not starting
daviemck2006
x 496
Xantia not starting
Unread post by daviemck2006 »
Got into Gabby, turned key, click and absolutely dead. Is there any known problems it could be?
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 1460
Re: Xantia not starting
Unread post by xantia_v6 »
Battery cables, battery...
Is anything electrical working? if not, it must be something close to the battery.
x 1488
Most likely the battery - modern ones have a tendency to die just like that one.
daviemck2006
x 496
Absolutely nothing working. Its left outside work just now. It will be ok there tonight. Ill have a fiddle with it tomorrow in daylight. Its been absolutely perfect, heard a relay click as I turned the key, the ign lights came on then off immediately. All I could see in the dark is that the battery terminals are ok!
Peugeot boxer 2016
In the family
daviemck2006
x 496
The jump leads are in gabbys boot. When she went dead instantly and completly I would suspect the earth strap has broken. That would be simple if a jump lead from the battery negative terminal to a decent earth restored operations. First thing to try tomorrow.
Peugeot boxer 2016
In the family
Zelandeth
x 1599
Unread post by Zelandeth »
It's a pretty new battery, so hopefully not that.
Earth strap would be my first suspect. Easy enough to test at least.
I know some Xantias have issues with the main battery positive lead degrading too (hence the sticky to that effect). Plus side is that it's a pretty fundamental fault so should hopefully be pretty easy to pinpoint.
Afraid I can't say "yes it happened now and then, it's because of..." though. Only power issue I had aside from the cooling fan gremlins was just down to an aged battery that was really past its best.
Current fleet:
daviemck2006
x 496
I thought the battery looked quite recent. The first thing I will try tomorrow will be a jump lead earth. Theres absolutely nothing, its as if a battery master switch has been switched, so hoping it is the earth strap gone, as that will be simple. Its like hellrazor said on your blog Zel, if a xantia is going perfect with no faults it will by default make a new fault for fun. Ive done over 4000 miles in Gabby now with, up until today, only a blown indicator bulb. Thats actually very impressive for the use she is getting, mostly all stop, start up and down the gears. Jim was going to do the clutch ladt summer, for the life of me I cannot see how its anywhere near a clutch. Iys lighter and more progressive than it was. The useage must of freed it off or something, and the other thing Jim had planned was the heater matrix. Im happy to report that she has a great heater, no smells from it, and never needed one drop of water, so as far as I am concerned there is no need for it either. She gets run down to the red mark on the fuel guage, gets 40 litres of new veg at 78p per litre and 12 to 15 litres of diesel in with it at 126.9p per litre here and runs like a dream on that.
Peugeot boxer 2016
In the family
x 8391
Battery was replaced just about a year ago Davie, with a brand new and good quality one... It conked out on me in Wiltshire at a parkrun and Alasdair had to come and recover me..
Zelandeth
x 1599
The heater matrix was always on my radar as I always caught a whiff of coolant as the heater warmed up. As you've found though she never has used a drop of coolant the whole time I had her. Likewise oil never budged between services. Given that I'd grown up with the belief that 100K was the end of the world for anything save for the odd Volvo, Mercedes or Saab that seemed almost impossible!
Still bothers me that when people mention cars that are capable of shrugging off mega miles that Citroen/Peugeot very rarely seem to get a look in.
Current fleet:
daviemck2006
x 496
Gabby just being a Citroen then. Absolutely nothing, put jump lead from negative on battery to earth, nothing, put jump leads on off of lilpug started instantly. I would have thought if the battery was so flat there was nothing it would have needed a while before it started. I need to go get new battery for my voltmeter to check the charge in the battery and from the alternator. At least she is home and cant be anything much. Im still not ruling out battery leads, both negative and positive after reading through the positive lead thread. I also need to pull my finger out and fix bigpug. Its not much use having 3 cars all mot, taxed and insured and one in bits, one misbehaving and the lowest mileage, oldest, best condition one being the only runner in the winter! I cant use the donutter as once in I really struggle to get out, and I'm not going to use the 107 as I have just noticed its in dire need of new front tyres, I told him and he shrugged his shoulders. I wash my hands of my son and cars. Im not ordering tyres for it.
Peugeot boxer 2016
In the family
x 1751
Davie, check the battery connectors and terminals for being clean and tight.
PSA originals can suddenly give up, and no longer make decent contact between the clamp and the thick bundle of copper cores inside. If either battery terminal feels at all warm (or hot) after trying to crank, that's a giveaway there's resistance there. Cut them off any replace with new brass ones, with the cores cleaned up, if blackened.
Possible Jim had done this already, of course.
daviemck2006
x 496
I will check them Chris, but been too busy today. I’m using the 205 today, get it a good going evening. It’s done nothing since coming home from the NC 500, it has a new distributor unit that hasn’t been properly tried out so it will be a good test for it. That will make an easier night for me, smaller car and left leg gets a rest lol
Peugeot boxer 2016
In the family
daviemck2006
x 496
Gabby has 12.4 volts in her battery, both clamps had worked their way loose is the only fault I could see. Once tightened she started no problem, and no heat in the clamps or wires. When running 14.6 volts at the alternator, and 14.58 at the battery, so theres nothing being lost along the way. I will have to put it down to the slack clamp losing its contact.
Peugeot boxer 2016
In the family
Michel
Unread post by Michel »
daviemck2006 wrote: 19 Dec 2017, 14:37 Gabby has 12.4 volts in her battery, both clamps had worked their way loose is the only fault I could see.
Ah. Jim has been "tightening" things again ;)
x 8391
Michel wrote: 19 Dec 2017, 15:13
:rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2:
Good job my cup of tea and keyboard were well separated this time ;)
Most likely guilty as charged m'lud :oops: :twisted:
Delighted all is now good again Davie 8-) :-D
