The list of things to do if the weather is kind and you can escape the famliy for a few hours...
307:
Required for MOT:
OSF spring and stut top bearing and drop link
NSR wheel bearing and damper
Possibly required for MOT:
Both front wishbones (which requires dismantling most of the front suspension, so would make sense to do the OS whilst the strut is out.
Needs doing:
Cambelt + Water pump
DPF clean (needs the water draining out and the rad removing to get enough room to get it out)
Thermostat
Starter (less said about that the better....)
Oil the gear cables
Grease the brakes
Picasso:
Remove the front seat and find out why it's jammed (again!)
Grease the rear brakes
Oil the gear cables
I've not managed to get any of the bits yet though, so that may hamper things a bit
