Davie's french attraction.
Fake Concern
x 65
Re: Davie's french attraction.
Unread post by Fake Concern »
daviemck2006 wrote: 14 Nov 2017, 23:34
Michel wrote: 14 Nov 2017, 23:31 Same size per axle, doesn't matter if front or rears are bigger.
I dont think the 5% difference in profile would really matter. But I want to run out the 40 profile anyway, if I put them on the back they will last forever!
I see what you mean all those burn outs.............
daviemck2006
x 496
Unread post by daviemck2006 »
Oil and filter changed on Gabby today. Easiest sump plug removal and easiest oil filter removal I have ever had. Thank you Jim or Zel, whoever last changed the oil, 7000 miles ago according to the dymo tape on the slam panel :)
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Michel
Unread post by Michel »
daviemck2006 wrote: 20 Nov 2017, 16:24 Oil and filter changed on Gabby today. Easiest sump plug removal and easiest oil filter removal I have ever had. Thank you Jim or Zel, whoever last changed the oil, 7000 miles ago according to the dymo tape on the slam panel :)
The Xantia is so easy to do the oil on. I used to do my TDs by putting the suspension on high, sticking an axle stand under one of the jacking points, and just reaching under to undo the drain plug and filter. So so easy. I'm not sure for others but for my 6ft I didn't really have to get "under" the car
Zelandeth
x 1593
Unread post by Zelandeth »
Reminds me, I've still got the tape printed out for Jim when he did the timing belt here somewhere!
Current fleet:
daviemck2006
x 496
Zelandeth wrote: 20 Nov 2017, 16:39 Reminds me, I've still got the tape printed out for Jim when he did the timing belt here somewhere!
There is tape there saying timing belt done, cant remember the date offhand, but its not that long ago.
Peugeot boxer 2016
In the family
x 8363
The last oil/filter would have been done by me Davie and I'm delighted the job was so easy for you this time... I never do filters or plugs up FT... There's just no need...
I did the cambelt and waterpump about a year ago as I remember... Around about 207K. I did not change any of the tensioners as they were all good for further duty...
Mike, yes, that's the beauty of Xantia suspension, it makes many jobs so easy... I really miss it when doing oil changes on the 207; not quite so bad on the Saxo as it sits a little further off the ground...
One thing I hate about doing the oil and filter on the 207 is the horrid cartridge filter :evil: I'm so pleased my Saxo is early enough to have the same 'spin-on' as fitted to all XU and earlier TU engines :)
Zel, better pop those tapes in the post I reckon ;)
Michel
CitroJim wrote: 20 Nov 2017, 17:14
Ah, yes, those. The C4 GP has one, I've no idea how to deal with it having never changed one before. I never bothered changing the oil on the 207 as it pissed it everywhere through all but the last few thousand miles we owned it.
x 8363
Basically Mike, undo the top with an almighty big socket and have a big bowl underneath to catch the spill that will run all over the filter housing and anything else in the vicinity!
Then retrieve and dispose of the oily old element. It will be very oily and will drip mess all over the place if you are not careful...
And even if you are careful it'll make a mess...
I wear disposable gloves and have a few old sandwich bags at the ready to put the old element in...
Use a new sealing ring upon replacement...
Not one of PSA's finest moments in my opinion :evil:
daviemck2006
x 496
I just had a guy approach me in Tescos carpark to talk xantias. He had done his time as an apprentice mechanic in a Citroen garage when the xantia was introduced and he loves them. He wanted to buy Gabby. I told him that he wouldnt give me enough monet to part with her. He said how about £600? The answer was still no. I didnt get her to make a quick profit. I got her because I wanted her, and still do want her. So that guys hunt for an xud xantia continues! Im keeping Gabby! If I wanted to sell a car just now it would be the 407.
Peugeot boxer 2016
In the family
Zelandeth
x 1593
Wouldn't think he'd have to hunt to far to find an XUD Xantia given their values these days...Now, one that drives half as well, that might be another matter!
Current fleet:
x 8363
Zelandeth wrote: 22 Nov 2017, 16:06 Now, one that drives half as well, that might be another matter!
Yes quite :) I still maintain that Gabby is the best 1.9TD out there... I've never known another to be as good and I've known enough of them...
Davie, you did the right thing to refuse the £600 :wink:
daviemck2006
x 496
I have this sneaky feeling that had I came on here and said I have sold her for £600 that you two guys with your communist connections would have sent an eastern bloc execution mob after me :missile: :missile: :missile: :missile: :rofl2: :rofl2: :rofl2:
Peugeot boxer 2016
In the family
x 8363
daviemck2006 wrote: 22 Nov 2017, 17:18 I have this sneaky feeling that had I came on here and said I have sold her for £600 that you two guys with your communist connections would have sent an eastern bloc execution mob after me :missile: :missile: :missile: :missile: :rofl2: :rofl2: :rofl2:
:rofl2:
Oh dear Davie, that made me absolutely howl!!!
But yes, we would have :twisted:
x 3566
CitroJim wrote: 21 Nov 2017, 05:11 Basically Mike, undo the top with an almighty big socket and have a big bowl underneath to catch the spill that will run all over the filter housing and anything else in the vicinity!
If it's this type of filter housing, then they're supposed to have a cut out in the threaded portion of the black plastic housing that breaks the airlock as you undo it and allows oil to drain back into the sump. Basically - pause before you fully unscrew the black housing !
Obviously, it never quite works how it should, but most of the oil goes back into the sump. :rofl2:
filter housing
filter housing
x 8363
bobins wrote: 22 Nov 2017, 19:30 If it's this type of filter housing, then they're supposed to have a cut out in the threaded portion of the black plastic housing that breaks the airlock as you undo it and allows oil to drain back into the sump. Basically - pause before you fully unscrew the black housing !
That's good to know :)
I'll take note and try that the next time I change the oil on the Pug of Love!
