xantia rear discs
mpr1956
xantia rear discs
Hi, has anyone replaced theirs recently? I want to replace mine but when I had a (half hearted) try at removing them while doing my swing arm bearings they were reluctant to even move so I left well alone at the time. Does anyone here have any removal tips please? ( The HBOL suggests that once the screw is removed they should almost fall off of the hub ) I have a 93 td sx.
- x 1431
Both mine just fell off after I removed the screws - despite the exceesive corrosion on and around the calipers.... The normal procedure is to remove the screws, then apply a hammer gently, then some heat, then some more hammer, then some more heat, then some more hammer, then if that fails, break out the angle grinder!
jeremy
mpr1956
