Dead key
- x 1938
Re: Dead key
You put the working key into the ignition, turned it and then went through the procedure on the non-working key?
Homer
- x 16
Re: Dead key
But surely it will be powered by induction (hence the transponder coil), not from the fob battery.GiveMeABreak wrote: 14 Nov 2017, 11:02 Hmmm... Not so sure Paul - this extract (for the X7 at least) would indicate that the Ignition Key Transponder also has some ability to perform a calculation. Probably another reason why the X7 only has the electrical remote fob if this is the case.
First - clarification of the terminology using this diagram:
(1) Ignition key with integral transponder.
(2) Transponder coil .
"a" Ignition key transponder.
Anyway that seems to be proven by the car starting with the fob battery removed.
- x 1938
Re: Dead key
That's for the transponder chip to be interrogated which is completely separate from the lock/unlock mechanism.
Whilst we all agree that ideally the key should be re-paired my contention is that it's not necessary if only the lock/unlock is needed.
The battery is ONLY for the lock/unlock. As you say the transponder chip gets its power from the coil.Homer wrote: 15 Nov 2017, 02:13Anyway that seems to be proven by the car starting with the fob battery removed.
