Hello all,
well i've decided that the fault listed above is due to a fault in the pressure regulation valve..
what i wanted to find out is
1. is the pressure valve and the converter lock up valve the same
2. Do i need to refill the auto transmission oil as recommended by the website Listed below
3. Should i just ignore since the issue is rare, and the transmission works fine in all areas of drive- city, hills, etc.
Never had the snow , sport triangle light flashing....
Just a knock , a jerk and the PRND light on rare occasions.
I believe someone here had a similar issue but theirs was more complicated...
I have included a pic of the parts i'm referring to.
The source:
http://www.peugeotlogic.com/workshop/ws ... lenoid.htm
Code P0006
Peugeot_Russ
Re: Code P0006
I forgot to ask, is upgrading the ECU necessary? Im using a real Lexia/Diagbox PP but never upgraded any ECUs.
Peugeot_Russ
Re: Code P0006
I am told i can use ESSO LT171141 ATF
- x 5671
Re: Code P0006
That is now Mobil LT171141. Same stuff, different branding. Can be hard to get and is quite expensive but the only one suitable for certain boxes.
Peugeot_Russ
Re: Code P0006
I am rethinking of interfering with this...... Any way i can check and fill the transmission fluid first? how is this done
