I have valprex valves on both my cars (V6 Activa and 1.9td) and they work fine for me. But as I said many people don't like them. Allegedly they start to leak...
Xantos and Xantia madness
xantos
- x 10
Re: Xantos and Xantia madness
No haven't tested it yet. I was thinking how to seal the plug tightening rod for about 2 years and then it struck me
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet
C4 Exclusive 2.0 HDi (gear shifting b****!)
- x 1751
Have used a good few 7mm Valprex valves, and only found one which wouldn't hold pressure.
Went looking for an O-ring a while back, as a slightly chubbier alternative to the rather thin (not much to compress) OE-size item that are supplied with Valprex valves. I had had one which leaked at the seal, despite inspection and cleaning.
Found this outfit...
http://www.polymax.co.uk/
who do a vast range of O-rings and other items, including Viton (FKM) rings...
http://www.polymax.co.uk/o-rings/rubber ... s178-viton
In this range, there is O-ring ref BS110V75, which has a cross-section of 2.62mm, rather than the OE/Valprex 2.00mm. ID and OD fit the valves fine, and there is a decent nip onto the ring when tightened. Normally use a smear of silcone grease on the ring as well, as it is a 'dry' joint.
The same O-ring will also fit Citroen OE sphere plugs.
xantos
- x 10
Well haven't been around for a while but done some work in the mean time...
Pictures say a thousand and ninety three words...
I didn't do anything like this before before you start criticizing take this into account. Class A DIY
OnlineCitroJim
- x 8210
Good work indeed and very useful pictures of how to do a great job of repairing what is now a common rust issue on the Xantia. Well done!
daviemck2006
- x 496
That looks like a top class repair. Both xantias I have owned needed remedial work there, although none were so bad as that. I believe that nearly every xantia which hasnt yet been repaired in that area will need soon. The current one did not look bad, just a little bubbling, but the MOT man put his thumb straight through it, which then fails the MOT as it is too close to a seatbelt mounting.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 1982
Nearly being the important word in that
daviemck2006
- x 496
I was thinking of yours when I added in the nearly!
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
- x 1982
Quite a few others, it is all down to end plugs and seam sealer
..............ohoower Matron !
