C5 mk 1 parking sensor control module.
demag
- x 102
Err where is it?
according to bol it's behind the r/h luggage panel but there's nothing there. If I start in park and move to reverse or d I get a beep beep every second or two. If I start in neutral and move to d then no beeps. The reverse sensors have always played up so think it might be associated. No warning messages, lights, nothing just bloody beeping. I though if I could unplug and try it, it might just prove if that's the prob. Got half the car stripped out now!
Dave
- x 6950
Re: C5 mk 1 parking sensor control module.
It's in the boot, rear driver's side, usually to the right of the spare wheel, mounted on the body - on the Mark I it may be behind the trim fabric though:
demag
- x 102
Found it by the spare wheel thanks Marc. Disconnected the sensors but still got the bleeping beep! So now I'm wondering does there need to be a resistance to register. I'm going to dig the laptop out.
Dave
- x 6950
It only takes one sensor to be faulty (usually water ingress) for the whole system to go on the blink - a safety issue -all or nothing! Lexia should be able to determine which if any are faulty though.
demag
- x 102
I did a Lexia session and the parking sensors read ok with no faults. There were a few other faults though but I erased most of them. Not being an expert I wanted to look at the engine parameters which I presume is done with Scantool. I got connected but it couldn't read anything but I'm not sure if that was down to me. Please see pics later.
Dave
MikeT
- x 232
Parameters are within the Lexia program, Dave.
My method (there may be a more efficient method I'm not aware of) is to choose the relevant ECU, scan for codes then clear them. Once that's done, the parameters sub-menu becomes available.
demag
- x 102
Ah thanks Mike. I'm still a newbie at this.
Dave
demag
- x 102
Some phone pics, they may appear sideways but I was the right way up at the time!
Also can I add a video file to this?
Dave
MikeT
- x 232
I'm not much further Dave, still a complete novice. I didn't know the scantool is supposed to work, it hasn't for me.
You can embed a youtube, is all I know.
- x 1486
We don't currently have a facility for uploading videos, so you must host it elsewhere, but youtube is a good choice.
demag
- x 102
My first ever YouTube video. I wonder if I will become rich?
Dave
demag
- x 102
Sussed it, I now have a silent car.
So here's a little tip for everyone, if you have a dashcam make sure you remember to replace the memory card when you remove it!
Dave
- x 6950
The words 'Top' and 'Hat' come to mind! I thought that doesn't sound like a parking sensor beep - but I never had this on my Mark I so didn't comment!
