must be a common problem on 3 door zxs.my last 2 volcanes have had the same problem along with my newest arrival.anyone have a common fix for this ? ALSO rear end RATTLE!!!! as on previous cars THE PARCEL SHELF!! its doing my bloody head in!!!have placed double sided sticky pads (used to mount number plates) to contacting areas,still no joy!!!
96 3dr volcane dt
leaky rear 1/4 windows
Stuart McB
If it's what I think it is. The catches that pull the window onto the seal may have streched over time. Two ways to sort, 1) replace seal with new as this will be thicker and give the catch more to pull against, 2) if you can adjust the catch tighten it up slightly. I think they ain't adjustable so go for seal change. Most good motor factors sell widow seal off the roll.
dan.2cv
rossnunn
