Wiring harness behind glove box
Fegquinn
Hi there, I have found this plug unplugged from behind glove box , for the life of me I can't find wer it plugs into a anyone out there know helpppppp thanks phil
- x 3283
Re: Wiring harness behind glove box
It is very possible that, on YOUR car, that plug is not used. Citroen (and other manufacturers) will only have a couple of wiring looms per model range. This helps them to save on production costs. For example, I know that, on my C5, there is the wiring in place for a CD multi-changer and heated/powered seats. However, I have neither fitted into my car (although they may well have been optional extras for her spec, and were standard equipment in higher spec models).
Fegquinn
Ok thanks for that mate
- x 6963
It would help if you mentioned what car you have, model and trim level or even better the VIN, so we can help identify the plug. I'll assume it's the Xsara in the profile though - what's your trim level?
- x 1056
Looks to me like the plug for the alarm ECU, im guessing you dont have the factory alarm
- x 6963
Or if you look at some of the wires, there should be a 4 or 5 digit code on them - posting a few of them will help too.
Fegquinn
Hi it's a spare cam plug, sorry I meant t o leave info xsara 1.4 2003 petrol lx 5 door hatch back
- x 6963
Yes, got that, but where you are holding the wires in the picture, there are 4 or 5 digit codes on the wires by your thumb. I can’t make them out, but if you can list a few of those codes if will help me identify the purpose of the plug
- x 1056
Im 99% sure that plug is for the alarm ECU which an LX model almost certainly wont have.
